10g sfp for ie3300
adeebtaqui
Level 4
Level 4
What 10g industrial sfp is recommended for ie3300 switches
Can SFP-10G-BXU-I be used and will connection work
if we can connect using single mode fiber patch cord, a  IE-3300-8U2X-E having SFP-10G-BXU-I= to another existing Cisco 9606R having SFP-10G-LR-S or any other existing other vendor switch having 10GbaseLX SFP.
Kindly advice if we can connect using single mode fiber patch cord, a  IE-3300-8U2X-E having SFP-10G-BXD-I= to another existing Cisco 9606R having SFP-10G-LR-S or any other existing other vendor switch having 10GbaseLX SFP.
Kindly advice if we connect using single mode fiber patch cord, a  IE-3300-8U2X-E having SFP-10G-BXU-I= to another IE-3300-8U2X-E having SFP-10G-BXU-I
Reza Sharifi
SFP-10G-BXD-I is a single-mode optic and it is supported on the IE-3300 switch. On the 9606 side, SFP-10G-LR-S is also single-mode and it is supported. So, it should work.
Both sides with the same optic type and the same switch. This should not be an issue at all.
Table-17 in this link list all the supported 10G SFPs.
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-ie3300-rugged-series/datasheet-c78-741759.html
shaun.oliver
The SFP-10G-BXU-I is a single-strand (not pair) Directional 10G SFP. The U in the part code is Up. It needs a SFP-10G-BXD-I (D = Down) at the other end.
If you need to use 10G LR on the other end, then you can use a 10G LR SFP in the IE-3300, but it's not an "Industrial" rated SFP.
