10G Speed on CAT6 ???
nabeelcse07
I have read that CAT6 can also provide 10G speed but upto a limited distance. Is this right ??
Please share any relevant link and information.
BL
Peter Paluch
Yes, Cat6 (not Cat6A) provides 10G Ethernet on cable spans on lengths of 55-100m depending on its screening, quality of installation and manufacturing. Check IEEE 802.3-2012 Standard, Section 4:
http://standards.ieee.org/getieee802/download/802.3-2012_section4.pdf
and consult Table 55-17 in Chapter 55.7.2.
Best regards,
Peter
Bilal Nawaz
Hello Nabeel,
I have also read it but never tested. There are multiple reasons why,
1 - i could not find SFP that will support a copper cat6 RJ45 end
2 - the supportability and reliability cannot be trusted.
In the past I have used fibre and twinax cables to establish 10Gb connectivity.
http://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/10GE_Tx_Matrix.html
http://www.cisco.com/c/en/us/products/collateral/interfaces-modules/transceiver-modules/data_sheet_c78-455693.html
Hope it helps.
Bilal
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Bilal,
Good points, my friend. As always, it is necessary to bridge theory and real life. The 10Gbase-T might formally be supported over plain Cat6 cabling but operational experiences and vendor support might render this support useless.
Best regards,
Peter
