10GB T module on 3750X
kardos420
Is it ok to use the 10GB-T ports in a 3750X module for server and/or Storage Array connectivity?  What are the downsides of doing this vs handing off to a 10GBT switch like a Nexus instead...  (port buffer, latency etc)
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
The 3750 series is a bit "infamous" for lack of port buffer resources causing egress drops.  However, depending how other ports and/or QoS are being used, buffer tuning and deactivation of QoS might (even totally) mitigate.
That said, unless your SAN is FC, there are other switches that might be suitable such as the 4500, 4900, 6500 and 6800 series.
