10gig switches
mohnegi
Hi all,
I am very new to cisco presales and had come accross a requirement as follows:-
24 fixed 10GBASE-T Ports and scalable up to 48 X 10 G Ports using upgrade Licenses.
Please help me with which model will fit the above requirement. thanks in advance.
Mark Malone
This may be close to what your looking fro 32 port upgradable to 48 with license , there may be a 24 port available just not aware of it
Configuration
   Cisco Nexus 3064-X
     48 fixed 10 Gigabit Ethernet SFP+ ports (can operate at 100-Mbps, 1-Gbps, and 10-Gbps speeds)
     Four fixed QSFP+ ports (each QSFP+ port can support 4 x 10 Gigabit Ethernet or 40 Gigabit Ethernet)
   Cisco Nexus 3064-T
     48 fixed 10GBASE-T ports (can operate at 100-Mbps, 1-Gbps, and 10-Gbps speeds)
   Cisco Nexus 3064-32T
     32 fixed 10GBASE-T ports (can operate at 100-Mbps, 1-Gbps, and 10-Gbps speeds)
     Upgrade to 48 fixed 10GBASE-T and 4 QSFP+ ports by installing a 16-port upgrade license
   Locator LED
Thanks Mark for your reply. I think N3K-C3172TQ-32T should also fit the requirement.
