03-25-2011 04:37 AM - edited 03-06-2019 04:15 PM
on the 3750x there are several bugs open .... LED not displayed correclty, SNMP polling for Power Supply and FAN does not repond corretly, ...
I opened TAC case for for the SNMP issue .... case is now closed with the answer that 12.2(58) will be released on march 14 2011 ... today is march 25 and the release is not yet available...
does anyone know when 12.2(58)SE will be available ?
thx
03-25-2011 04:58 AM
Honestly, 12.2(58)SE - is a much awaited release - it should be out by mid of April 2011 or by the end of that month.
ranraju
03-25-2011 03:48 PM
Thanks for this info. I'll be keeping an eye out for this long-awaited release.
10-24-2011 12:13 AM
we have Problems with SNMP indices for FANs and POWER SUPPLIES and IOS 15.0.1
Is your problem fixed in meanwhile ?
best regards
Herbert
10-24-2011 11:17 PM
I did just a quick test .... it seems that there are still problems with fan modules... power supplies monitoring looks good.
Do you have problems also with Power supply monitoring ?
10-25-2011 12:17 AM
We have problems with powers supplies and fans, with release 12.2.55 until 15.0.1.
These are the minor problems ...
Major problems arise with link problems with Broadcom NICs (except the PoE version)
regards
Herbert
10-25-2011 12:37 AM
Which kind of problems do you have with Broadcom NICs ? I have several 3750x installed and i have not noticed problems with Broadcom NICs ... do oyu have open case or know bugs ?
thx, bye, gilberto
10-25-2011 12:51 AM
The Bug ID is CSCts62136.
We have reproduced the problem with several servers (not only with Broadcom 5708), the problem was oberved between 2 3560x, too. A affected Server is now on the way to Cisco, we will see what the root cause is.
regards,
Herbert
03-17-2015 08:03 AM
We were informed by TAC about this command:
Switch(config)# interface gi1/0/X
Switch(config-int)# no physleep enable
Does it fix the problem with Broadcom NetXtreme NIC?
03-17-2015 08:19 AM
yes, TAC built that command for work around this issue
