Catalyst 2950 Password Reset
khansen011
Hey Guys I need some help!!!
I have never used a managed switch till today. I have a switch that we use to use but it was managed by a 3rd party company.
Long story short I have the switch hooked up to Hyper terminal all is set up im able to connect to it. It is asking for a username and password.
The problem is that i dont know what it is and the company will not give it to me.
How do i reset this password or reset the whole device to bran new!!
I was doing some reading on line and it said to hold in the mode button while plugging in the power. but i did not know what to do after that....
please help!
Note: I have attached a few doc that i hope will help you help me :) !
Charles Hill
Take a look at this document.
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-2950-series-switches/12040-pswdrec-2900xl.html
This document describes the password recovery procedure for the Cisco Catalyst Layer 2 fixed configuration switches 2900XL/3500XL, 2940, 2950/2955
If this helps, please rate.
Charles Hill
Thank you for your reply
I found this video on youtube
https://www.youtube.com/watch?v=r88HmwQGd0s
Works Great And was able to get in!
