15.0(2)SE1 "Right To Use" / IP SERVICES features
jtoque
Hello, since no more license is required due to RTU recently announced by Cisco for IOS 15.0(2)SE1, is there any CLI command to activate IP SERVICES features on this IOS.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750x_3560x/software/release/15.0_2_se/release/notes/OL25302.html#wp1065409
Support for Right-To-Use (RTU) licensing, which  allows you to upgrade from one license level to another by entering  commands in the command line interface without interacting with the  Cisco Product License Registration portal.
We have to upgrade many C3K switchs already in IP SERVICES from 15.0(2)SE to 15.0(2)SE1.
One more question: One of our switch is in IP SERVICES demo license, do we have to install the definitive license before upgrading to 15.0(2)SE1 ?
Thanks a lot.
Julien.
jtoque
I just find this "license right-to-use activate"
http://www.cisco.com/en/US/docs/ios-xml/ios/csa/command/csa-l1.html#GUID-62E59938-36CC-4BDD-9E67-E4318E8E8E15
I'll try this tomorrow morning, i will post the result if it fails.
