15.0SY Policy-based queueing input on WS-X6816-2T
sokarlsson
I'm trying to configure policy-based queueing with dscp-based WRED on a VSS system with Sup2T-10GE sup and WS-X6816-2T line cards.
According to "show queueing" interface command the ports in shared mode support the following queueing:
Transmit queues [type = 1p7q4t]
Receive queues [type = 1p7q2t]
I have also checked the data sheet for the WS-X6816-10GE and this say the same
Oversubscription mode:
• Receive: 1p7q2t per port
• Transmit: 1p7q4t per port group
Config snippet:
class-map type lan-queuing match-all REALTIME-QUEUE
  match  dscp cs4  cs5  ef
class-map type lan-queuing match-all CONTROL-QUEUE
  match  dscp cs2  cs3  cs6  cs7
class-map type lan-queuing match-all MULTIMEDIA-CONFERENCING-QUEUE
  match  dscp af41  af42  af43
class-map type lan-queuing match-all MULTIMEDIA-STREAMING-QUEUE
  match  dscp af31  af32  af33
class-map type lan-queuing match-all TRANSACTIONAL-DATA-QUEUE
  match  dscp af21  af22  af23
class-map type lan-queuing match-all BULK-DATA-QUEUE
  match  dscp af11  af12  af13
class-map type lan-queuing match-all SCAVENGER-QUEUE
  match  dscp cs1
policy-map type lan-queuing 1P7Q2T
  class REALTIME-QUEUE
    priority
  class CONTROL-QUEUE
    bandwidth remaining percent 10
  class MULTIMEDIA-CONFERENCING-QUEUE
    random-detect dscp-based aggregate
    random-detect dscp values 34 percent 80 100
    random-detect dscp values 36 38 percent 70 100
  class MULTIMEDIA-STREAMING-QUEUE
    random-detect dscp values 26 percent 80 100
    random-detect dscp values 28 30 percent 70 100
  class TRANSACTIONAL-DATA-QUEUE
    random-detect dscp values 18 percent 80 100
    random-detect dscp values 20 22 percent 70 100
  class BULK-DATA-QUEUE
    bandwidth remaining percent 4
    random-detect dscp values 10 percent 80 100
    random-detect dscp values 12 14 percent 70 100
  class SCAVENGER-QUEUE
  class class-default
    random-detect dscp 0 percent 80 100
policy-map type lan-queuing 1P7Q4T
    priority
  class CONTROL-QUEUE
    random-detect dscp 34 percent 80 100
    random-detect dscp 36 percent 70 100
    random-detect dscp 38 percent 60 100
    random-detect dscp 26 percent 80 100
    random-detect dscp 28 percent 70 100
    random-detect dscp 30 percent 60 100
    random-detect dscp 18 percent 80 100
    random-detect dscp 20 percent 70 100
    random-detect dscp 22 percent 60 100
    random-detect dscp 10 percent 80 100
    random-detect dscp 12 percent 70 100
    random-detect dscp 14 percent 60 100
  class class-default
Attaching the output queueing policy-map "1P7Q4T" to an interface in output direction works fine and both "show running interface" and "show queueing interface" commands confirm the policy is enabled OK.
interface TenGigabitEthernet1/2/1
switchport
switchport mode trunk
udld port aggressive
service-policy type lan-queuing output 1P7Q4T
LINKCORE-01#show queueing int te1/2/1
Interface TenGigabitEthernet1/2/1 queueing strategy:  Weighted Round-Robin
  Port QoS is enabled globally
  Queueing on Te1/2/1: Tx Enabled Rx Enabled
Trust boundary disabled
  Trust state: trust DSCP
  Trust state in queueing: trust DSCP
  Extend trust state: not trusted [COS = 0]
  Default COS is 0
    Class-map to Queue in Tx direction
    Class-map           Queue Id
    REALTIME-QUEUE            8
    CONTROL-QUEUE             7
    MULTIMEDIA-CONFERENC      6
    MULTIMEDIA-STREAMING      5
    TRANSACTIONAL-DATA-Q      4
    BULK-DATA-QUEUE           3
    SCAVENGER-QUEUE           2
    class-default             1
    Queueing Mode In Tx direction: mode-dscp
    Transmit queues [type = 1p7q4t]:
The input queueing policy though is driving me nuts. I can not get the policy to work with random-detect dscp-based or
random-detect dscp-based aggregate in any class. If I attach a policy with any sort of rand-detect command in a class, the switch swallows the interface command and it looks like it replicate it to the other ports in the port-group (remember we are in oversubscription mode here) without complaining. If I then check the interface config there is no service-policy type lan-queueing input there.
If I remove all random-detect commands from the classes it will however be applied OK and it looks like it works.
According to the QOS config guide for 15.0SY 1p7q2t interfaces should support this. I have also tried random-detect cos-based and random-detect
multiple-type-based. None of these seem to be supported.
This however works fine as a lan-queueing input policy
policy-map type lan-queuing TEST-INPUT
    priority
  class CONTROL-QUEUE
  class class-default
I can not find anything in bug-search so at least it does not look like a documented bug. Am I doing something wrong?
9 Replies 9
sokarlsson
Have had a rather long winding case with TAC about this. Interfaces with 1p7q2T ingress queues do not support WRED. Tis is a documentation error. One must use tail-drop for these. On top of that the documentation do not state that T2 has a fixed value of 100%. The final queue config for 1p7q2T ingress ended up like this
policy-map type lan-queuing 1P7Q2T-TailDrop-IN
    priority
  class CONTROL-QUEUE
    queue-limit multiple-type-base
    queue-limit dscp values 36 38 percent 80
    queue-limit dscp values 34 percent 100
    queue-limit dscp values 28 30 percent 80
    queue-limit dscp values 26 percent 100
    queue-limit dscp values 20 22 percent 80
    queue-limit dscp values 18 percent 100
    queue-limit dscp values 12 14 percent 80
    queue-limit dscp values 10 percent 100
  class class-default
Why would you ever use ingress queues? Usually policing is the only necessary action on access port input service policies.
I know this is a really old comment, but to answer the question "Why would you ever use ingress queues?"
One reason to use ingress queues is if your backplane is oversubscribed such as on the Cat-6880.
Old comments are tracked. New comments are welcome. (-:
Marc, I would be interested in the case study if you have a nice Cat6880-X QoS experience.
Hi Peter,
I'm trying to do the same thing on the egress side - ie output.  However, I'm running 15.1.2SY6 on a standalone 6880-x-le.  I can't assign the service-policy to the interface.
I have platform qos queuing-only set but I'm literally grasping at straws right now.  What are the pre-requisite config's required to enable an egress policy.
Rash
If you have and bandwidth reserved under  class-default it is not supported. If you remove the bandwidth and then apply it it will work.
https://supportforums.cisco.com/discussion/12523971/6807-sup2t-qos-queuing-config-mqc
Also see this bugCSCur92556
Hi Steve,
Here is my policy.  I don't have bandwidth associated with class-default.
policy-map type lan-queuing UPLINK_EGRESS
  class PRIORITY
    priority
  class NETWORK-CTRL
    queue-buffers ratio 10
    queue-limit dscp cs3 percent 100
    queue-limit dscp cs6 percent 100
    queue-limit dscp cs7 percent 100
  class SLF-GOLD-PLUS
    bandwidth remaining percent 20
    queue-buffers ratio 15
    queue-limit dscp af31 percent 90
    queue-limit dscp af41 percent 100
  class GOLD
    random-detect dscp 16 percent 70 100
    random-detect dscp 18 percent 90 100
  class SILVER
    bandwidth remaining percent 25
    queue-buffers ratio 20
    random-detect dscp 10 percent 90 100
    random-detect dscp 12 percent 80 100
    random-detect dscp 14 percent 70 100
  class class-default
    queue-buffers ratio 25
    random-detect dscp values 0 1 2 3 4 5 6 7 percent 70 100
    random-detect dscp values 8 9 11 13 15 17 19 21 percent 70 100
    random-detect dscp values 23 25 27 29 31 33 35 37 percent 70 100
    random-detect dscp values 39 41 42 43 44 45 47 49 percent 70 100
    random-detect dscp values 50 51 52 53 54 55 57 58 percent 70 100
    random-detect dscp values 59 60 61 62 63 percent 70 100
bha01ad1(config-if)#service-policy type lan-queuing output UPLINK_EGRESS
bha01ad1#sh run inter te1/4
Load for five secs: 6%/0%; one minute: 4%; five minutes: 4%
Time source is NTP, 09:43:06.137 edt Tue Mar 22 2016
Building configuration...
Current configuration : 447 bytes
interface TenGigabitEthernet1/4
 dampening
 mtu 9216
 ip address 10.86.244.5 255.255.255.254
 no ip proxy-arp
 ip pim query-interval 1
 ip pim sparse-mode
 ip igmp version 3
 ip ospf network point-to-point
 ip ospf dead-interval 3
 ip ospf hello-interval 1
 ip ospf bfd
 logging event link-status
 logging event nfas-status
 logging event bundle-status
 load-interval 30
 carrier-delay msec 0
 hold-queue 300 in
end
So I'll remove the pieces buffer piece right now and try.
Cheers,
Rash
Hi Peter,
In regards to your response - "but this is a routed port, not a switch port".  I've modified the policy to reflect the following:'
policy-map UPLINK_EGRESS
  class PRIORITY
    priority
  class NETWORK-CTRL
  class GOLD-PLUS
  class GOLD
  class SILVER
  class class-default
I still have issues.  With matching COS in the class-map.
routerb(config-if)#service-policy output UPLINK_EGRESS
Match cos is not supported for this interface in the output direction.
routerb(config-if)#exit
After removing the "cos" match statements I get the following that I need to remove the priority.
priority command is not supported in output direction for this interface
Configuration failed!
Here is the interface config
interface TenGigabitEthernet2/4
 mvrp timer leave-all 1000
 mvrp timer leave 60
 mvrp timer join 20
 no mvrp timer periodic
 no mvrp
 no access-group hardware share label bridge-domain
 dampening
 mtu 9216
 ip address 10.86.244.7 255.255.255.254
 ip redirects
 ip unreachables
 no ip proxy-arp
 ip mtu 9216
 ip pim dr-priority 1
 ip pim sparse-mode
 ip mfib forwarding input
 ip mfib forwarding output
 ip mfib cef input
 ip mfib cef output
 ip cef accounting non-recursive internal
 ip load-sharing per-destination
 ip route-cache cef
 ip route-cache
 ip split-horizon
 ip igmp last-member-query-interval 1000
 ip igmp last-member-query-count 2
 ip igmp query-max-response-time 10
 ip igmp version 3
 ip igmp query-interval 60
 ip igmp tcn query count 2
 ip igmp tcn query interval 10
 ip ospf resync-timeout 40
 ip ospf retransmit-interval 5
 ip ospf transmit-delay 1
 no ip ospf flood-reduction
 no ip ospf demand-circuit
 no ip ospf mtu-ignore
 no ip ospf database-filter all out
 ip ospf bfd
 ip ospf cost 1
 load-interval 30
 keepalive 10
 platform multicast forwarding ip
 platform multicast forwarding ipv6
 no platform ip features sequential
 no platform ip directed-broadcast include-router
 no platform ip directed-broadcast exclude-router
 no platform ip directed-broadcast drop
 led beacon
 ipv6 nd reachable-time 0
 ipv6 nd ns-interval 0
 ipv6 nd dad attempts 1
 ipv6 nd prefix framed-ipv6-prefix
 ipv6 nd nud igp
 ipv6 nd ra lifetime 1800
 ipv6 nd ra interval 200
  ipv6 redirects
  ipv6 unreachables
 ipv6 mfib forwarding input
 ipv6 mfib forwarding output
 ipv6 mfib cef input
 ipv6 mfib cef output
 no mab
 snmp trap link-status
 cts role-based enforcement
 macro description
 storm-control broadcast level 100.00
 storm-control multicast level 100.00
 storm-control unicast level 100.00
 load-balance src-dst-ip
 load-balance src-dst-mac
 load-balance src-dst-port
 load-balance dst-ip
 load-balance dst-mac
 load-balance src-mac
 load-balance src-ip
 load-balance vlan
 load-balance mpls
 no dot1ad uni
 no arp arpa
 arp timeout 14400
   clns route-cache
 spanning-tree port-priority 128
 ethernet oam max-rate 10
 ethernet oam min-rate 1
 ethernet oam remote-loopback timeout 2
 ethernet oam timeout 5
 ethernet oam mtu 1518
 hold-queue 300 in
 no bgp-policy accounting
 no bgp-policy accounting output
 no bgp-policy accounting input source
 no bgp-policy accounting output source
 no bgp-policy source ip-prec-map
 no bgp-policy source ip-qos-map
 no bgp-policy destination ip-prec-map
 no bgp-policy destination ip-qos-map
Peter Koltl
Level 7
Level 7
But this is a routed port, not a switchport.
