17.3.3 vs 16.12.7 for PoE equipements
sysadm_uvsq
We have two C9200-24P with two different IOS XE versions: 17.3.3 and 16.12.7.
On each switch we have connected un PoE equipment SimonsVoss .
On the same condition, same configuraton, on the 16.12.7 version these devices work well, on the 17.3.3 version these devices receive the IP by dhcp but it is impossible to ping. What could be the right configuration to do on the new version under IOSXE to correct this problem
6 Replies 6
marce1000
 - Could you verify if the SimonsVoss device is actually using the received ip address , by verifying the ip configuration (such as ipconfig /all on Windows). Use similar or equivalent commands on  the device to verify the status of the  ip-stack.
 M.
thanks
I wll do that !
Leo Laohoo
Downgrade to 16.12.7.
I downgraded but it is a solution fot short term
Seems a bug that is resolved in 17.3.4.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvx11287
Jitendra
sysadm_uvsq
Hi Kumar, everybody,
indeed, it's working with 17.3.5 !
Thanks a lot !
