1841 config problem
dhanikonda
Level 4
Level 4
Dear sir,
i have cisco 1841 router connected to isp1(v.35)and i have broadband 1 mbps link (rj-45) thesetwo
outpouts r terminated on switch .
now we want to configure these broadband also terminated on router one of the fasteth port and
we want to ethernet failover and loadbalance on the router.
This setup is possible if possible plz give me some tips.
Thanks&Regards
srini
JORGE RODRIGUEZ
Level 11
Level 11
you could accomplish both if both isp terminate on same router, assume ISP1 interface Ip is 20.20.20.1, ISP2 interface IP 30.30.30.1, inside LAN 192.168.1.0
interface serial0/0
Description ISP1
ip address 20.20.20.1 255.255.255.252
ip nat outside
interface fe0/1
Description ISP2
ip address 30.30.30.1 255.255.255.252
ip nat outside
interface fE0/0
ip nat inside
ip nat pool ISP1 20.20.20.1 20.20.20.1 netmask 255.255.255.252
ip nat pool ISP2 30.30.30.1 30.30.30.1 netmask 255.255.255.252
ip nat inside source route-map ISP1 pool ISP1 overload
ip nat inside source route-map ISP2 pool ISP2 overload
ip access-list standard localLAN
permit 192.168.1.0 0.0.0.255
route-map ISP1
match ip address localLAN
match interface s0/0
route-map ISP2
match interface fe0/1
ip route 0.0.0.0 0.0.0.0 20.20.20.2 <- ISP1 next hop router interface ip
ip route 0.0.0.0 0.0.0.0 30.30.30.2 <- ISP2 next hop router interface ip
Jorge
Jorge Rodriguez
