1861 Port config Issue
mohammed.rahman
I am trying to config on of the port as L3 port. I tried no switchport command but didn't take it. Anybody has any idea.
Jon Marshall
Mohammed
It depends on the HWIC card/ Network module as to whether the ports can be configured as routed ports.
If they can't then what you need to do is create a vlan using "vlan database", then create a L3 vlan interface and then assign your port into that vlan.
Jon
