1941 configuration with range of WAN ip addresses
robbie.teo
i have a 1941 router tt needs to be setup with the range of WAN ip addresses
ip nat inside outside don't allow me to use it
For example,
WAN --------- (129.1.1.1/30)  Router ( 129.2.1.1/28) -------------------- (129.2.1.2) Firewall
How can i configure on the router to ensure from outside i'm able to access to firewall (129.2.1.2) ?
PLs Advice. Thanks
Eugene Khabarov
Level 7
Level 7
For what purpose you need access your firewall? Is it management requirements? Do I understand you right that you can't use NAT on your wan interfaces?
HTH. Please rate this post if it was helpful. If this solves your problem, please mark this post as "Correct Answer."
For Vpn access.
If i use NAT, i can't be able to access the firewall WAN ip address.
Any advice on this? thanks.
Confiuration will be helpful here...
Hi Robbie,
You don't need NAT. Just assign your FW with the public IP address 129.2.1.2/28 and it shoud be routed or accessible from the Internet.
