1941 Router Does not keep config when turned off
Eddie.brown1986
Hello Everyone,
I have a 1941 integrated services router that will not keep the configs. After several atempts of saving running config to the startup config, then rebooting the device. I am having to reload the configs manually from TFTP because they are gone. I have also tryed the "wr" command to see if that would help but still nothing.
Is there a proper way to shutdown this particular type of router?
Eddie
Benjamin Kools
Could be an issue with your configuration register. If you do a show version, look at the last line of output:
A value of 0x2142 is used for password recovery - basically it tells the router to boot with out the saved configuration. If you do a show startup-config you should be able to verify your configuration is actually there. To change this back to the default, issue the following commands:
R1#     conf t
R1(config)#config-register 0x2102
Benjamin Kools
R1#     conf t
Thank you so much for the quick response.
I just applied and reloaded and it stayed!
Awesome job.
Thanks a lot, it was helpful for me.
