1941 Router Rommon Mode recory problem (Interface GE 0 link down)
afroz khan
Dear Friend,
i am try to recover my Router (1941 with serial Card) from rommon mode prosses is below but problem is there showing error (Interface GE 0 link down) i am also try with both cable like cross and streght but problem is still there Note :- Ge0/0 prot was up in Boot time i have also attach Router Log file in atach file
rommon 1 > IP_ADDRESS=192.168.1.1
rommon 2 > IP_SUBNET_MASK=255.255.255.0
rommon 3 > DEFAULT_GATEWAY=192.168.1.1
rommon 4 > TFTP_SERVER=192.168.1.32
rommon 5 > TFTP_FILE=c1700-k9sv8y7-mz.122-15.T14.bin
rommon 6 > tftpdnld
          IP_ADDRESS: 192.168.1.1
      IP_SUBNET_MASK: 255.255.255.0
     DEFAULT_GATEWAY: 192.168.1.1
         TFTP_SERVER: 192.168.1.32
           TFTP_FILE: c1700-k9sv8y7-mz.122-15.T14.bin
        TFTP_MACADDR: e0:5f:b9:a2:69:a0
    TFTP_DESTINATION: flash0:
             GE_PORT: Ge0/0
     TFTP_MEDIA_TYPE: Copper
        TFTP_VERBOSE: Progress
    TFTP_RETRY_COUNT: 18
        TFTP_TIMEOUT: 7200
       TFTP_CHECKSUM: No
       GE_SPEED_MODE: 1000MB/FULL
Invoke this command for disaster recovery only.
WARNING: all existing data in all partitions on flash will be lost!
Do you wish to continue? y/n:  [n]:  y
TFTP: Operation terminated prematurely.
10 Replies 10
afroz khan
I have also try with new Image file
(c1900-universalk9-mz.SPA.152-4.M4.bin)
rommon 5 > TFTP_FILE=c1900-universalk9-mz.SPA.152-4.M4.bin
rommon 6 > tftpdnld
           TFTP_FILE:c1900-universalk9-mz.SPA.152-4.M4.bin
             GE_PORT: Ge0/0
        TFTP_TIMEOUT: 7200
       TFTP_CHECKSUM: No
Sandeep Choudhary
Hi ,
I was having same problem to load the IOS, I think it will be good for you to load ios from xmodem.
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a008015bfac.shtml
Step 1: rommon 12 > xmodem -cfs115200 c1900-universalk9-mz.SPA.152-4.M4.bin
Step2 :Select Transfer and Send File from the HyperTerminal menu bar. (see the link)
it will take long time
Dear ,
I Have try with Xmodem prosses but problem is still there
NOTE:- Router Model 1941
Leo Laohoo
Afroz,
This is a DUPLICATE thread to this.
As I have pointed this out to you in your other thread, you are trying to load an IOS for a 1700 router into your 1900 router.
And this, I can assure you, will not work.
NOTE:  You will be able to copy the file into the 1900 router but that's where it ends.
Dear Leo Laohoo
I Habe try with
c1900-universalk9-mz.SPA.152-4.M4.bin but problem is still there problem with Ge0/0 port  wich is taken by default
but when we try to give ip by below mention method but ge0 port is not coming Up
rommon 6 > tftpdnld
             GE_PORT: Ge0/0
        TFTP_TIMEOUT: 7200
       TFTP_CHECKSUM: No
hi,
i think you should set your DEFAULT_GATEWAY and TFTP_SERVER to be on same IP address with your PC/laptop.
try to make it simple and use 192.168.1.2. using a straight cable should be no problem.
Dear,
I have given IP Address in below step
Router IP
Subnet Mask
Default Gateway
PC IP IS
Image File Name
Afroz,
1.  Power down the router;
2.  Eject the CF;
3.  Get a multi-card reader;
4.  Use a PC to copy the IOS from your PC to the CF using the multi-card reader;
5.  Insert the CF back to the router.
6.  Power on the router.
Please don't forget to rate our useful posts.
Dear ,
Ge0/0 Port is enbelt in Router Mother Board it it not posibale to remove the Ge0/0 Port from the router
resaga
hi Afroz,
i think that you have problem with speed, be sure that the speed of the network card from the laptop or PC is 1 GB, else you must set speed to 100, with command GE_SPEED_MODE:
