1941w - 2 ssid's 2 vlans and 2 bvi interfaces - routing issue
richardbowden
Hello All,
I have been given the 1941w to configure for our office, done some cisco work in the past, but nothing like this....i have it 99% configured apart from the liitle issue.
This is what I have configured, attached are the config files for the router and ap.
gig 0/0 is internet access
FOR LAN ACCESS
dhcp pool 172.16.0.0/24
gig 0/1 is lan (vlan 1 and in bvi 1)
wireless ssid 00110101 (vlan 1 and bvi 1)
FOR WIRELESS GUEST ACCESS ONLY
dhcp pool 172.16.1.0/24
wireless ssid cloudyguest (vlan 2 and bvi 2)
both wireless and lan can access the internet ok through gig 0/0 using ip's on their own subnet's
Please may i ask, would some one be kind enough to go over my config as although it works is it the correct way to do things, i have used the cisco doc's a lot to get it this far.
Also my problem, although i have not speccified to route between vlan 1 and 2 i can ping ip's on either side and access file shares for example on both sides, ideally the lan and lan wifi should be able to talk to each other and get internet, and guest wifi cloudyguest internet only...not sure how to do the last bit, i did try adding a acl to to each bvi interface for 172.16.0.0 0.0.255.255...this kind of worked but was not able to ping the gateway ip for each subnet.
thanks in advance
best regards
richard
dddcooke1
Level 4
Level 4
Hi Richard, Did you every get this resolved?  I'm having similar issue.
3 Vlans 3 SSIDs
ssid SMH-NATIVE VLAN 1 192.168.10.0/24
ssid SMH-Employees VLAN 2 192.168.20.0/24
ssid SMH-VOIP VLAN 4 192.168.40.0/24
On the wired side I can ping devices on different VLANs across the wire.
On the WiFi I can only ping devices on vlan1 and get a DHCP assignment.  Vlan 2 & 3 can not ping and no DHCP.
Thanks for looking
AP Config
Current configuration : 3206 bytes
version 12.4
no service pad
service password-encryption
hostname ap
logging rate-limit console 9
enable secret 5 $1$YkUa$k/lBfSWQHoM2uh/VsFgdb.
no aaa new-model
dot11 syslog
dot11 ssid SMH-Employees
vlan 2
authentication open
authentication key-management wpa version 2
mbssid guest-mode
wpa-psk ascii 7 096D63272924242159
dot11 ssid SMH-NATIVE
vlan 1
authentication open
mbssid guest-mode
wpa-psk ascii 7 1128342B2733383F55
dot11 ssid SMH-VOIP
vlan 4
authentication open
mbssid guest-mode
wpa-psk ascii 7 14363F253C25191877
username Cisco password 7 047802150C2E
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 1 mode ciphers aes-ccm
encryption vlan 2 mode ciphers aes-ccm
encryption vlan 4 mode ciphers aes-ccm
ssid SMH-Employees
ssid SMH-NATIVE
ssid SMH-VOIP
antenna gain 0
mbssid
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.2
encapsulation dot1Q 2
no ip route-cache
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
bridge-group 2 spanning-disabled
interface Dot11Radio0.4
encapsulation dot1Q 4
no ip route-cache
bridge-group 4
bridge-group 4 subscriber-loop-control
bridge-group 4 block-unknown-source
no bridge-group 4 source-learning
no bridge-group 4 unicast-flooding
bridge-group 4 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
antenna gain 0
dfs band 3 block
channel dfs
station-role root
bridge-group 1
interface GigabitEthernet0
description the embedded AP GigabitEthernet 0 is an internal interface connecting AP with the host router
no ip address
no ip route-cache
interface GigabitEthernet0.1
no ip route-cache
bridge-group 1
interface GigabitEthernet0.2
no ip route-cache
interface GigabitEthernet0.4
no ip route-cache
interface BVI1
ip address 192.168.10.2 255.255.255.0
no ip route-cache
interface BVI2
ip address 192.168.20.2 255.255.255.0
no ip route-cache
interface BVI4
ip address 192.168.40.2 255.255.255.0
no ip route-cache
ip default-gateway 192.168.20.1
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
no activation-character
line vty 0 4
login local
Router Config
Building configuration...
Current configuration : 3235 bytes
! Last configuration change at 20:19:17 UTC Mon Dec 14 2020
version 15.1
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
service-module wlan-ap 0 bootimage autonomous
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 192.168.10.1 192.168.10.30
ip dhcp excluded-address 192.168.20.1 192.168.20.30
ip dhcp excluded-address 192.168.40.1 192.168.40.30
ip dhcp pool SMH-NATIVE
network 192.168.10.0 255.255.255.0
dns-server 8.8.8.8
default-router 192.168.10.1
ip dhcp pool SMH-Employees
network 192.168.20.0 255.255.255.0
default-router 192.168.20.1
dns-server 8.8.8.8
ip dhcp pool SMH-VOIP
network 192.168.40.0 255.255.255.0
default-router 192.168.40.1
dns-server 8.8.8.8
license udi pid CISCO1941W-A/K9 sn FTX161683ET
license boot module c1900 technology-package securityk9
hw-module ism 0
vtp domain Houston
vtp mode transparent
redundancy
vlan 2-4
vlan 7
name 104F-Primary
vlan 8
name 104F-IOT
vlan 9
name 104F-GUEST
vlan 10
name WIFI
vlan 11,13
vlan 20
name home
vlan 30
name comcast
vlan 70
name WIFI70
vlan 80
name WIFI80
vlan 100
interface Embedded-Service-Engine0/0
no ip address
interface GigabitEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface wlan-ap0
description Service module interface to manage the embedded AP
ip unnumbered Vlan1
arp timeout 0
no mop enabled
no mop sysid
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Wlan-GigabitEthernet0/0
description uplink to AP
switchport mode trunk
no ip address
interface GigabitEthernet0/0/0
no ip address
interface GigabitEthernet0/0/1
no ip address
interface GigabitEthernet0/0/2
no ip address
interface GigabitEthernet0/0/3
no ip address
interface GigabitEthernet0/1/0
no ip address
interface GigabitEthernet0/1/1
no ip address
interface GigabitEthernet0/1/2
no ip address
interface GigabitEthernet0/1/3
no ip address
interface GigabitEthernet0/1/4
no ip address
interface GigabitEthernet0/1/5
no ip address
interface GigabitEthernet0/1/6
no ip address
interface GigabitEthernet0/1/7
switchport access vlan 2
no ip address
interface Vlan1
description SMH-NATIVE
ip address 192.168.10.1 255.255.255.0
interface Vlan2
description SMH-Employees
ip address 192.168.20.1 255.255.255.0
interface Vlan4
description SMH-VOIP
ip address 192.168.40.1 255.255.255.0
router eigrp 10
network 0.0.0.0
