08-08-2017 12:11 PM - edited 03-08-2019 11:40 AM
I've been looking for an expansion slot on a cisco 1941w router that would give it more FastEthernet ports so that more computers can be connected to it. I'm having some trouble finding what part this would be. Does anyone know what it is or if it's even supported?
thank you
Solved! Go to Solution.
08-08-2017 01:07 PM
Have a look at this compatibility matrix.
EHWIC-D-8ESG-P (8 port)
EHWIC-D-4ESG (4 port)
Link
https://www.cisco.com/c/en/us/products/routers/1900-series-integrated-services-routers-isr/relevant-interfaces-and-modules.html#esm
08-08-2017 01:07 PM
Link
