2 ip address 1 interface
cgianluigi
Community Member
is possible assegning 2 ip address in 1 interface?how? sorry for my bad english...
ankbhasi
Hi Friend,
Yes thats possible with secondary keyword.
Something like this
config t
int fa0/1
ip address
ip address secondary
Ankur
*pls rate all helpfull post
Thanks for the information, I thought to resolve a problem but I have not succeeded. I try to explain.
I have 4 lines aggregate with a router 7200. (to see attached scheme). I have available 128 public ip addresses.
On the interface gigabitethernet 0/2 I have configure one of ip address public to which I have connected a switch.
Connected to the switch I have a router 2810 with another public ip address.
I have to configure a vpn as a connected remote pc to internet through modem and without an address static ip.
I have tried the configuration that I write under. If I try to connect to the public ip address of the router 2810 the configuration work.
The same configuration if I connect me to the router 7200 it doesn't allow me the connection; if I connect me from the pc1 (with one of the 128 addresses disposition ip) then it works.
How can I connect to the router 7200 directly? What do I have to add to the configuration?
Thanks for the help
Allegato la configurazione che ho utilizzato presa da un documento cisco.
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
service internal
hostname Cisco
Cisco Systems, Inc.
All contents are Copyright ? 1992?2004 Cisco Systems, Inc. All rights reserved. Important Notices and Privacy Statement.
Page 6 of 9
aaa new-model
aaa authentication login userlist local
aaa authorization network hw-client-groupname local
aaa session-id common
enable password cisco
username cisco password 0 xxxxxx
memory-size iomem 15
clock timezone - 0 6
ip subnet-zero
no ip source-route
ip domain-name cisco.com
ip audit notify log
ip audit po max-events 100
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp client configuration address-pool local dynpool
crypto isakmp client configuration group hw-client-groupname
key hw-client-password
dns 30.30.30.10 30.30.30.11
wins 30.30.30.12 30.30.30.13
domain cisco.com
pool dynpool
crypto ipsec transform-set transform-1 esp-3des esp-sha-hmac
crypto dynamic-map dynmap 1
set transform-set transform-1
reverse-route
crypto map dynmap client authentication list userlist
crypto map dynmap isakmp authorization list hw-client-groupname
crypto map dynmap client configuration address respond
crypto map dynmap 1 ipsec-isakmp dynamic dynmap
interface Ethernet0/0
description connected to INTERNET
ip address 20.20.20.2 255.255.255.0
half-duplex
no cdp enable
crypto map dynmap
interface FastEthernet0/0
description connected to HQ LAN
ip address 30.30.30.1 255.255.255.0
Cisco Systems, Inc.
Page 7 of 9
speed auto
no cdp enable
ip local pool dynpool 30.30.30.20 30.30.30.30
ip classless
ip route 0.0.0.0 0.0.0.0 Ethernet0/0
no ip http server
ip pim bidir-enable
no cdp run
line con 0
line aux 0
line vty 0 4
password xxxxxxxxxx
end
