Cisco 4003 code upgrade
Nickfulstow
Community Member
I have two 4003's wich are in need of a code upgrade.
I will have to update the rommon and Catos
The code it is using is years old.
Do I have to load code in sequential order or can I load the latest code ?
Nick
glen.grant
You need to upgrade the rommon first if the main code release calls for it . The instructions can be found in the release notes for the particular code version you plan to use.
