2 ip ranges 1 Switch
Timo85
im new here and relatively new to networks i have a job coming up that requires a site to have 2 ip ranges for cctv cameras.
my question is:
will their be a conflict if you have 2 ip ranges running through one switch?
i will have 2 servers each using a different ip range each with x amount of cameras for example
server 1 192.168.1.x
server 2 193.168.2.x
if I run both these ranges through the same SG300 switch will they cause issues to one another.
balaji.bandi
You can run both the IP range from same switch,
by creating 2 VLAN for example below : and allocate port to respected VLAN for them to work.
VLAN 10 - 192.168.1.x
VLAN 11 - 192.168.2.x
BB
BB
Thanks for the quick reply, would it definitely cause conflicts if VLANS were not used? I thought that would be the case needing to create “VLANS” but wanted to clarify that. How would that work with regards to viewing both servers from the same viewing PC around the site I know you can give pc’s 2 ip addresses but would that still work if VLANS were created?
Timo
since you want 2 separate networks, you SHOULD use VLANs to create the logical separation.  without them, you would have to create a network that contained both subnets (BAD IDEA, large broadcast domain).  As for viewing the cameras from one PC, then you just need to advertise the route.  (the vlan interfaces will act as a gateway and act as "router on a stick".  You would then restrict access with an ACL down the line, hopefully a router or ASA
example
vlan 2
name CAMERA_NET1
VLAN 3
name CAMERA_VLAN2
interface vlan 2
description SVI for camera Network 1
ip address 172.16.1.1 255.255.255.0
interface vlan 3
ip address 172.16.2.1 255.255.255.0
interface range g1/1-5
switchport mode access
switchport access vlan 2
switchport nonegotiate
interface g1/6-10
switchport access vlan 3
Vince
