??-2 physical connections on 1 Serial interface-??
osatronix
Hi there
I'm in the middle of setting up CCENT lab. I've 2 1721 routers conected via DCE/DTE cable [R2 is set to DCE]. Router 1 is connected to Router 2 on serial interface and to a 2950 switch on fast ethernet interface. Router 2 is also connected directly to my laptop on fast ethernet interface.
For some reason when I use ''show ip route'' command on both of my routers they're showing that they are connected to 3 subnets. I dont understand why is it showing physical connection to this network:  192.168.1.65/32 ??
Please can someone explain me what I'm doing wrong??
Below I'm attaching config files and command outputs.
My subnets:
I            192.168.1.0  -    192.168.1.63
II           192.168.1.64 - 192.168.1.127
III          192.168.1.128 - 192.168.1.191
IV          192.168.1.192 - 192.168.1.255
255.255.255.192
Thanks.
Router1#show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
     192.168.1.0/24 is variably subnetted, 3 subnets, 2 masks
C       192.168.1.65/32 is directly connected, Serial0
C       192.168.1.64/26 is directly connected, Serial0
C       192.168.1.128/26 is directly connected, FastEthernet0
Router1
Current configuration : 709 bytes
version 12.4
service password-encryption
hostname Router1
boot-start-marker
boot-end-marker
enable secret 5 $1$Y69O$E4Iao7lfz2z65DeRSVtt2/
no aaa new-model
ip cef
archive
log config
  hidekeys
interface FastEthernet0
ip address 192.168.1.129 255.255.255.192
speed auto
interface Serial0
ip address 192.168.1.66 255.255.255.192
encapsulation ppp
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
password 7 070B345C4F
login
line aux 0
line vty 0 4
password 7 121D100713
login
end
R2#show ip route
C       192.168.1.66/32 is directly connected, Serial0
C       192.168.1.0/26 is directly connected, FastEthernet0
R2#show running-config
Building configuration...
Current configuration : 813 bytes
version 12.4
hostname R2
boot-start-marker
boot-end-marker
enable secret 5 $1$Dp3y$klKPKWSqsd3U99.jHtEro1
no aaa new-model
ip cef
archive
log config
  hidekeys
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
dsl operating-mode auto
ip address 192.168.1.2 255.255.255.192
speed auto
interface Serial0
ip address 192.168.1.65 255.255.255.192
encapsulation ppp
clock rate 2000000
no ip http server
control-plane
line con 0
password 7 1413071B0D
login
line aux 0
line vty 0 4
password 7 0202114B0A
login
end
Lukasz
The explanation for this is that the serial link is using ppp encapsulation. And as the router brings up the serial interface the ppp protocol uses IPCP negotiation to learn the address of the neighbor and then it puts that address into the routing table as a connected network and as a /32 since that is what ppp learned about its neighbor.
Rick
Rick
7 Replies 7
Reza Sharifi
That is correct.  On r1 route table:
192.168.1.65 is the IP address of the serial interface of the neigbor router and that is a host address (/32)
the second one (192.168.1.64/26) is the subnet for the serial interface between r1 and r2
The 3rd one is the subnet for the FastEthernet interface of the router
Thanks thats a bit clearer now. But still I don't understand why the subnet mask is /32 while 2 other masks are /26.
If you could explain it I will be much appreciated.
Thanks a lot.
/32 the address of r2 serial interface and there is C next to it, so it is a directly connected interface.  Then you have 2 /26 masks, one is the one you created for the serial interface that connects r1 and r2 together and the other one is the one you created for the fastEthernet interface.  They also each have a C next to them and that means they are directly connected or local subnets.
Now, since you do not have any static routes on r1 or r2, you will not be able to ping from a host (PC/Laptop) connected to r1 to a host connected to r2 and vice versa. If you want to have full connectivity between hosts connected to r1 and r2 you need a static route on each router as follows:
r1
ip route 192.168.1.0 255.255.255.192  192.168.1.66
r2
ip route 192.168.1.128 255.255.255.192  192.168.1.65
Please remember to tag your threads and help support "Teachers without Borders"
https://supportforums.cisco.com/community/netpro/idea-center/communityhelpingcommunity
Thanks for your help.
I literally finished setting up static routing for them just before I checked your recent post and I can now connect to all the devices on my network. HURRAY.
The reason I've asked for that third physical (C) connection was that I've watched tutorial video in which tutor sets up a similar layout. In his routing table there are only two C's appears  -
1st for the network on the serial interface side and
2nd for the network on the fastethernet side
What is he saying is that routers knows only about the networks that they are physically connected to - so following this logic my routers are only connected to two networks each and what i don't understand is why [as you stated]
''/32 the address of r2 serial interface and there is C next to it, so it is a directly connected interface''
routers recognizing serial interface of other router as a network??
It really annoys me.
Thank you very much.
Lukasz
Rick
Rick
osatronix
Thanks a lot guys!!
Lukasz
I am glad that our responses were able to lead you to a solution to this issue. Thank you for using the rating system to mark this question as answered (and thanks for the points). It makes the forum more useful when people can read a question and can know that a solution was found. Your marking of this question has contributed to this process.
Rick
Rick
