Showing results forĀ
Search instead forĀ
Did you mean:Ā
2 stacks of 9200Ls located in different closets drop together
sphillips
Good evening,
I have 2-9200Ls stacked together in IDF1 closet and 2-9200Ls stacked together in IDF2 closet. I recently had something happen at the same time last week and I lost 140 ports for approx. 5 minutes. My cameras on  the active and standby switch on the stack in IDF-1 went down and the cameras on the active switch in IDF-2 dropped. Out of both stacks, only the standby switch in IDF2 stayed up. Each closet is independent of each other, their on separate power supply's, on separate circuits and separate vlan's. My IT department is on the same circuit as me and they didn't lose any of their equipment. We also have backup UPS generators which didn't kick on so I don't think this was a power issue. The logs show the active switch was removed on both stacks at the same time. Has anyone witness this before. I compared my show techs to a show tech taken a few months prior and it looks like the active switch is now in standby and what was in standby is now in active, like the swapped places. I read about a reboot bug and I'm currently on version 16.9.3. What's the odds the same issue caused both stacks of switches to reboot. Why did one standby switch stay up but the other didn't when they are basically configured the exact same. It's very unlikely to have 2 separate stacks of switches reboot at the same time and it's left me very confused. Ideas?
sphillips
I forgot to add the last 12 LED status lights for 1/0/37 - 48 don't light up at all. All my cameras on those ports are working correctly just no status lights at all.
Leo Laohoo
Post the complete output to the following commands:
  1. sh version
  2. sh log on switch active up detail
  3. dir flash:
  4. dir flash:core
  5. dir crashinfo:
The show logs on IDF2 doesn't go back as far as IDF1 did. I took a show tech report on the day of the actual outage and noticed it showed the active switch was removed from both stacks so I'm assuming if the show log from IDF2 went back as far it would look similar to the show log for IDF1.
HERE IS THE COMMAND YOU REQUESTED FOR IDF1
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2022.07.13 11:02:43 =~=~=~=~=~=~=~=~=~=~=~=
User Access Verification
Password:
IDF_1>en
Password:
IDF_1#sh ver
Cisco IOS XE Software, Version 16.09.03
Cisco IOS Software [Fuji], Catalyst L3 Switch Software (CAT9K_LITE_IOSXE), Version 16.9.3, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2019 by Cisco Systems, Inc.
Compiled Wed 20-Mar-19 07:19 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2019 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
BOOTLDR: System Bootstrap, Version 16.12.1r [FC2], RELEASE SOFTWARE (P)
IDF_1 uptime is 2 years, 33 weeks, 2 hours, 8 minutes
--More--  Uptime for this control processor is 2 years, 33 weeks, 2 hours, 10 minutes
System returned to ROM by SSO Switchover
System restarted at 07:57:03 EST Mon Nov 25 2019
System image file is "flash:packages.conf"
Last reload reason: unknown reload cause - reason ptr 0xF, PC 0x0,address 0x0
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
--More--
Technology Package License Information:
Technology-package Technology-package
Current Type Next reboot
network-advantage Smart License network-advantage
dna-advantage Subscription Smart License dna-advantage
Smart Licensing Status: UNREGISTERED/EVAL MODE
cisco C9200L-48P-4X (ARM64) processor with 519464K/3071K bytes of memory.
Processor board ID JAE23380GKN
2 Virtual Ethernet interfaces
96 Gigabit Ethernet interfaces
8 Ten Gigabit Ethernet interfaces
2048K bytes of non-volatile configuration memory.
1998932K bytes of physical memory.
819200K bytes of Crash Files at crashinfo:.
1941504K bytes of Flash at flash:.
0K bytes of WebUI ODM Files at webui:.
819200K bytes of Crash Files at crashinfo-1:.
1941504K bytes of Flash at flash-1:.
Base Ethernet MAC Address : 4c:71:0d:ac:05:80
Motherboard Assembly Number : 73-19245-06
Motherboard Serial Number : JAE23380GKN
Model Revision Number : G0
Motherboard Revision Number : A0
Model Number : C9200L-48P-4X
System Serial Number : JAE23380GKN
Switch Ports Model SW Version SW Image Mode
1 52 C9200L-48P-4X 16.9.3 CAT9K_LITE_IOSXE INSTALL
* 2 52 C9200L-48P-4X 16.9.3 CAT9K_LITE_IOSXE INSTALL
Switch 01
Switch uptime : 1 week, 5 days, 2 hours, 0 minutes
Base Ethernet MAC Address : 68:3b:78:c4:84:00
Motherboard Assembly Number : 73-19245-05
Motherboard Serial Number : JAE232710BV
Model Revision Number : E0
System Serial Number : JAE232710BV
Configuration register is 0x102
IDF_1#sh log
Syslog logging: enabled (0 messages dropped, 31 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
Console logging: level debugging, 576 messages logged, xml disabled,
filtering disabled
Monitor logging: level debugging, 0 messages logged, xml disabled,
filtering disabled
Buffer logging: level debugging, 578 messages logged, xml disabled,
filtering disabled
Exception Logging: size (4096 bytes)
Count and timestamp logging messages: disabled
File logging: disabled
Persistent logging: disabled
No active filter modules.
Trap logging: level informational, 562 message lines logged
Logging Source-Interface: VRF Name:
Log Buffer (8192 bytes):
itEthernet1/0/24, changed state to down
Jul 1 09:06:27: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/25, changed state to down
Jul 1 09:06:28: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/22, changed state to down
Jul 1 09:06:28: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/27, changed state to up
Jul 1 09:06:28: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/38, changed state to up
Jul 1 09:06:28: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/28, changed state to down
Jul 1 09:06:28: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/26, changed state to down
Jul 1 09:06:28: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/30, changed state to down
Jul 1 09:06:28: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/24, changed state to down
Jul 1 09:06:29: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/31, changed state to down
Jul 1 09:06:29: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/32, changed state to down
Jul 1 09:06:29: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/38, changed state to up
Jul 1 09:06:29: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/26, changed state to down
Jul 1 09:06:29: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/30, changed state to down
Jul 1 09:06:29: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/40, changed state to down
Jul 1 09:06:30: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/31, changed state to down
Jul 1 09:06:30: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/32, changed state to down
Jul 1 09:06:30: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/42, changed state to down
Jul 1 09:06:30: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/44, changed state to down
Jul 1 09:06:30: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/40, changed state to down
Jul 1 09:06:31: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/42, changed state to down
Jul 1 09:06:31: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/44, changed state to down
Jul 1 09:06:38: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/2, changed state to up
Jul 1 09:06:39: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/6, changed state to up
Jul 1 09:06:39: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/2, changed state to up
Jul 1 09:06:40: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/8, changed state to up
Jul 1 09:06:40: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/10, changed state to up
Jul 1 09:06:40: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/6, changed state to up
Jul 1 09:06:41: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/12, changed state to up
Jul 1 09:06:41: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/8, changed state to up
Jul 1 09:06:41: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/10, changed state to up
Jul 1 09:06:41: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/14, changed state to up
Jul 1 09:06:42: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/12, changed state to up
Jul 1 09:06:42: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/16, changed state to up
Jul 1 09:06:42: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/20, changed state to up
Jul 1 09:06:42: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/14, changed state to up
Jul 1 09:06:42: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/18, changed state to up
--More--  Jul 1 09:06:43: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/16, changed state to up
Jul 1 09:06:43: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/20, changed state to up
Jul 1 09:06:43: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/25, changed state to up
Jul 1 09:06:43: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/22, changed state to up
Jul 1 09:06:43: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/18, changed state to up
Jul 1 09:06:44: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/28, changed state to up
Jul 1 09:06:44: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/24, changed state to up
Jul 1 09:06:44: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/25, changed state to up
Jul 1 09:06:44: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/22, changed state to up
Jul 1 09:06:45: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/30, changed state to up
Jul 1 09:06:45: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/28, changed state to up
Jul 1 09:06:45: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/26, changed state to up
Jul 1 09:06:45: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/24, changed state to up
Jul 1 09:06:45: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/31, changed state to up
Jul 1 09:06:45: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/32, changed state to up
Jul 1 09:06:46: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/30, changed state to up
Jul 1 09:06:46: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/26, changed state to up
Jul 1 09:06:46: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/40, changed state to up
Jul 1 09:06:46: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/31, changed state to up
Jul 1 09:06:46: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/32, changed state to up
Jul 1 09:06:47: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/42, changed state to up
Jul 1 09:06:47: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/44, changed state to up
Jul 1 09:06:47: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/40, changed state to up
Jul 1 09:06:48: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/42, changed state to up
Jul 1 09:06:48: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/44, changed state to up
Jul 1 09:07:35: %IOSXE_REDUNDANCY-6-PEER: Active detected switch 1 as standby.
Jul 1 09:07:35: %STACKMGR-6-STANDBY_ELECTED: Switch 2 R0/0: stack_mgr: Switch 1 has been elected STANDBY.
Jul 1 09:07:45: %REDUNDANCY-5-PEER_MONITOR_EVENT: Active detected a standby insertion (raw-event=PEER_FOUND(4))
Jul 1 09:07:45: %REDUNDANCY-5-PEER_MONITOR_EVENT: Active detected a standby insertion (raw-event=PEER_REDUNDANCY_STATE_CHANGE(5))
Jul 1 09:08:21: %HA_CONFIG_SYNC-6-BULK_CFGSYNC_SUCCEED: Bulk Sync succeeded
Jul 1 09:08:22: %RF-5-RF_TERMINAL_STATE: Terminal state reached for (SSO)
Jul 1 10:11:16: %WEBSERVER-5-LOGIN_PASSED: Switch 2 R0/0: nginx: Login Successful from host 192.168.100.204 by user 'admin'
Jul 1 10:12:47: %SYS-6-TTY_EXPIRE_TIMER: (exec timer expired, tty 2 (192.168.100.204)), user
Jul 1 11:33:10: %SYS-6-TTY_EXPIRE_TIMER: (exec timer expired, tty 2 (192.168.100.204)), user
Jul 1 13:02:31: %SYS-6-TTY_EXPIRE_TIMER: (exec timer expired, tty 2 (192.168.100.204)), user
Jul 1 14:28:10: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/42: PD removed
Jul 1 14:28:11: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/42, changed state to down
Jul 1 14:28:12: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/42, changed state to down
Jul 1 14:28:12: %ILPOWER-7-DETECT: Interface Gi1/0/42: Power Device detected: IEEE PD
Jul 1 14:28:13: %ILPOWER-5-POWER_GRANTED: Interface Gi1/0/42: Power granted
Jul 1 14:28:22: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/42, changed state to up
Jul 1 14:28:23: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/42, changed state to up
Jul 1 14:28:50: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/42, changed state to down
Jul 1 14:28:51: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/42, changed state to down
Jul 1 14:29:07: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/42, changed state to up
Jul 1 14:29:08: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/42, changed state to up
Jul 1 15:00:20: %WEBSERVER-5-LOGIN_PASSED: Switch 2 R0/0: nginx: Login Successful from host 192.168.100.204 by user 'admin'
Jul 1 15:25:42: %SYS-6-TTY_EXPIRE_TIMER: (exec timer expired, tty 2 (192.168.100.204)), user
IDF_1#dir flash:
Directory of flash:/
16194 -rwx 344552977 Dec 31 1969 19:38:34 -05:00 cat9k_lite_iosxe.16.09.03.SPA.bin
16195 drwx 4096 Nov 25 2019 08:10:01 -05:00 .installer
16197 -rw- 333 Nov 25 2019 08:10:02 -05:00 bootloader_evt_handle.log
16198 drwx 4096 Sep 22 2019 03:22:33 -04:00 core
40481 drwx 4096 Sep 22 2019 03:37:54 -04:00 .prst_sync
56673 drwx 4096 Sep 22 2019 03:33:57 -04:00 .rollback_timer
64769 drwx 4096 Sep 22 2019 03:20:02 -04:00 tech_support
72865 drwx 4096 Nov 25 2019 08:10:17 -05:00 dc_profile_dir
16196 -rw- 140 Nov 25 2019 08:10:19 -05:00 boothelper.log
16200 -rw- 123888 Nov 25 2019 08:10:37 -05:00 memleak.tcl
16202 drwx 4096 Sep 22 2019 03:22:51 -04:00 .dbpersist
16203 -rw- 2097152 Dec 25 2021 11:06:06 -05:00 nvram_config
16204 -rw- 2097152 Dec 25 2021 11:06:06 -05:00 nvram_config_bkup
16205 drwx 4096 Sep 22 2019 03:22:11 -04:00 onep
16207 -rw- 35 Sep 22 2019 03:22:43 -04:00 pnp-tech-time
16208 -rw- 67741 Sep 22 2019 03:22:54 -04:00 pnp-tech-discovery-summary
16199 -rw- 140 Nov 21 2019 14:48:49 -05:00 boothelper.log.old
16229 -rw- 4877 Sep 22 2019 03:31:30 -04:00 packages.conf
16210 -rw- 616 Nov 25 2019 08:15:23 -05:00 vlan.dat
16230 -rw- 299176972 Sep 22 2019 03:30:56 -04:00 cat9k_lite-rpbase.16.09.03.SPA.pkg
16233 -rw- 34935297 Sep 22 2019 03:31:30 -04:00 cat9k_lite-rpboot.16.09.03.SPA.pkg
16231 -rw- 3101708 Sep 22 2019 03:30:56 -04:00 cat9k_lite-srdriver.16.09.03.SPA.pkg
16232 -rw- 7586824 Sep 22 2019 03:30:56 -04:00 cat9k_lite-webui.16.09.03.SPA.pkg
16214 -rw- 616 Jul 1 2022 09:07:52 -04:00 stby-vlan.dat
1956839424 bytes total (1156886528 bytes free)
IDF_1#dir flash:core
Directory of flash:/core/
48578 drwx 4096 Sep 22 2019 03:20:00 -04:00 modules
16206 -rw- 1 Jul 13 2022 10:59:04 -04:00 .callhome
IDF_1#dir crashinfo:
Directory of crashinfo:/
11 -rw- 0 Dec 31 1969 19:00:53 -05:00 koops.dat
29313 drwx 24576 Jul 13 2022 11:03:17 -04:00 tracelogs
12 -rw- 622648 Jul 1 2022 09:00:24 -04:00 IDF_1_2_RP_0_trace_archive_0-20220701-090023.tar.gz
825638912 bytes total (778436608 bytes free)
IDF_1#exit
HERE IS THE COMMAND YOU REQUESTED FOR IDF2
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2022.07.13 11:04:57 =~=~=~=~=~=~=~=~=~=~=~=
Username: admin
Password:
IDF_2>en
Password:
IDF_2#sh ver
software.
ROM: IOS-XE ROMMON
BOOTLDR: System Bootstrap, Version 16.10.1r [FC5], RELEASE SOFTWARE (P)
IDF_2 uptime is 2 years, 31 weeks, 6 days, 29 minutes
--More--  Uptime for this control processor is 2 years, 31 weeks, 4 days, 22 hours, 11 minutes
System restarted at 11:58:14 EST Wed Dec 4 2019
export@cisco.com.
--More--
Processor board ID JAE23220Z3Y
--More--  1941504K bytes of Flash at flash:.
Base Ethernet MAC Address : 68:3b:78:c4:62:00
Motherboard Serial Number : JAE23220Z3Y
System Serial Number : JAE23220Z3Y
Switch 01
Switch uptime : 1 week, 5 days, 2 hours, 3 minutes
--More--
Base Ethernet MAC Address : 4c:71:0d:91:70:00
Motherboard Serial Number : JAE23380H4X
System Serial Number : JAE23380H4X
IDF_2#sh log
Syslog logging: enabled (0 messages dropped, 58 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
Console logging: level debugging, 1270 messages logged, xml disabled,
filtering disabled
filtering disabled
Buffer logging: level debugging, 1260 messages logged, xml disabled,
filtering disabled
--More--
Trap logging: level informational, 1304 message lines logged
et2/0/39, changed state to up
Jul 1 16:48:47: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/39, changed state to down
Jul 1 16:48:48: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/39, changed state to down
Jul 1 16:49:04: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/39, changed state to up
Jul 1 16:49:05: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/39, changed state to up
Jul 1 16:54:12: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/39, changed state to down
Jul 1 16:54:13: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/39, changed state to down
Jul 1 16:54:19: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/39, changed state to up
Jul 1 16:54:20: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/39, changed state to up
Jul 1 16:54:47: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/39, changed state to down
--More--  Jul 1 16:54:48: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/39, changed state to down
Jul 1 16:55:04: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/39, changed state to up
Jul 1 16:55:05: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/39, changed state to up
Jul 1 17:00:11: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/39, changed state to down
Jul 1 17:00:12: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/39, changed state to down
Jul 1 17:00:19: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/39, changed state to up
Jul 1 17:00:20: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/39, changed state to up
Jul 1 17:00:47: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/39, changed state to down
Jul 1 17:00:48: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/39, changed state to down
Jul 1 17:01:04: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/39, changed state to up
Jul 1 17:01:05: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/39, changed state to up
Jul 1 17:06:12: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/39, changed state to down
Jul 1 17:06:13: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/39, changed state to down
Jul 1 17:06:19: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/39, changed state to up
Jul 1 17:06:20: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/39, changed state to up
Jul 1 17:06:47: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/39, changed state to down
Jul 1 17:06:48: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/39, changed state to down
Jul 1 17:07:04: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/39, changed state to up
Jul 1 17:07:05: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/39, changed state to up
Jul 1 17:09:51: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi2/0/39: PD removed
Jul 1 17:09:51: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/39, changed state to down
Jul 1 17:09:52: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/39, changed state to down
Jul 1 17:24:00: %ILPOWER-7-DETECT: Interface Gi2/0/39: Power Device detected: IEEE PD
Jul 1 17:24:01: %ILPOWER-5-POWER_GRANTED: Interface Gi2/0/39: Power granted
Jul 1 17:24:09: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/39, changed state to up
Jul 1 17:24:10: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/39, changed state to up
Jul 1 17:24:38: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/39, changed state to down
Jul 1 17:24:39: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/39, changed state to down
Jul 1 17:24:54: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/39, changed state to up
Jul 1 17:24:55: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/39, changed state to up
Jul 1 17:27:24: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi2/0/39: PD removed
Jul 1 17:27:24: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/39, changed state to down
Jul 1 17:27:25: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/39, changed state to down
Jul 1 17:39:27: %ILPOWER-7-DETECT: Interface Gi1/0/18: Power Device detected: IEEE PD
Jul 1 17:39:28: %ILPOWER-5-POWER_GRANTED: Interface Gi1/0/18: Power granted
Jul 1 17:39:36: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/18, changed state to up
Jul 1 17:39:37: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/18, changed state to up
Jul 1 17:40:05: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/18, changed state to down
Jul 1 17:40:06: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/18, changed state to down
Jul 1 17:40:22: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/18, changed state to up
Jul 1 17:40:23: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/18, changed state to up
Jul 1 17:45:30: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/18, changed state to down
Jul 1 17:45:31: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/18, changed state to down
Jul 1 17:45:37: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/18, changed state to up
Jul 1 17:45:38: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/18, changed state to up
Jul 1 17:45:52: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/18, changed state to down
Jul 1 17:45:52: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/18: PD removed
Jul 1 17:45:53: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/18, changed state to down
Jul 1 17:57:08: %ILPOWER-7-DETECT: Interface Gi1/0/18: Power Device detected: IEEE PD
Jul 1 17:57:09: %ILPOWER-5-POWER_GRANTED: Interface Gi1/0/18: Power granted
Jul 1 17:57:17: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/18, changed state to up
Jul 1 17:57:18: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/18, changed state to up
Jul 1 17:57:47: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/18, changed state to down
Jul 1 17:57:48: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/18, changed state to down
Jul 1 17:58:03: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/18, changed state to up
Jul 1 17:58:04: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/18, changed state to up
Jul 1 18:17:18: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/18: PD removed
Jul 1 18:17:18: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/18, changed state to down
Jul 1 18:17:19: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/18, changed state to down
Jul 1 18:31:52: %ILPOWER-7-DETECT: Interface Gi1/0/18: Power Device detected: IEEE PD
Jul 1 18:31:53: %ILPOWER-5-POWER_GRANTED: Interface Gi1/0/18: Power granted
Jul 1 18:32:01: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/18, changed state to up
Jul 1 18:32:02: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/18, changed state to up
--More--  Jul 1 18:32:32: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/18, changed state to down
Jul 1 18:32:33: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/18, changed state to down
Jul 1 18:32:49: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/18, changed state to up
Jul 1 18:32:50: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/18, changed state to up
Jul 4 14:00:43: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/42, changed state to down
Jul 4 14:00:44: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/42, changed state to down
Jul 4 14:00:50: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/42, changed state to up
Jul 4 14:00:51: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/42, changed state to up
Jul 4 14:01:19: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/42, changed state to down
Jul 4 14:01:20: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/42, changed state to down
Jul 4 14:01:36: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/42, changed state to up
Jul 4 14:01:37: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/42, changed state to up
Jul 13 11:05:01: %SEC_LOGIN-5-LOGIN_SUCCESS: Login Success [user: admin] [Source: 192.168.100.204] [localport: 23] at 11:05:01 EDT Wed Jul 13 2022
IDF_2#  dir flash:
32386 -rwx 344552977 Dec 31 1969 19:39:06 -05:00 cat9k_lite_iosxe.16.09.03.SPA.bin
32387 drwx 4096 Dec 4 2019 12:03:38 -05:00 .installer
32389 -rw- 444 Dec 4 2019 12:03:39 -05:00 bootloader_evt_handle.log
32390 drwx 4096 Jul 8 2019 23:15:15 -04:00 core
56673 drwx 4096 Dec 3 2019 08:25:28 -05:00 .prst_sync
72865 drwx 4096 Jul 8 2019 23:26:40 -04:00 .rollback_timer
80961 drwx 4096 Jul 8 2019 23:12:39 -04:00 tech_support
89057 drwx 4096 Dec 4 2019 12:03:56 -05:00 dc_profile_dir
32391 -rw- 139 Dec 4 2019 12:03:57 -05:00 boothelper.log
32392 -rw- 123888 Dec 4 2019 12:04:15 -05:00 memleak.tcl
32394 drwx 4096 Jul 8 2019 23:15:33 -04:00 .dbpersist
32402 -rw- 2097152 Dec 25 2021 15:32:18 -05:00 nvram_config
32396 -rw- 2097152 Dec 25 2021 15:32:19 -05:00 nvram_config_bkup
32397 drwx 4096 Jul 8 2019 23:14:53 -04:00 onep
32399 -rw- 34 Jul 8 2019 23:15:24 -04:00 pnp-tech-time
32400 -rw- 67731 Jul 8 2019 23:15:36 -04:00 pnp-tech-discovery-summary
32388 -rw- 139 Dec 3 2019 09:43:49 -05:00 boothelper.log.old
32421 -rw- 4877 Jul 8 2019 23:24:14 -04:00 packages.conf
32406 -rw- 616 Jul 1 2022 09:06:23 -04:00 stby-vlan.dat
32422 -rw- 299176972 Jul 8 2019 23:23:39 -04:00 cat9k_lite-rpbase.16.09.03.SPA.pkg
32425 -rw- 34935297 Jul 8 2019 23:24:14 -04:00 cat9k_lite-rpboot.16.09.03.SPA.pkg
32423 -rw- 3101708 Jul 8 2019 23:23:39 -04:00 cat9k_lite-srdriver.16.09.03.SPA.pkg
32424 -rw- 7586824 Jul 8 2019 23:23:39 -04:00 cat9k_lite-webui.16.09.03.SPA.pkg
32395 -rw- 616 Dec 4 2019 12:07:43 -05:00 vlan.dat
IDF_2#dir flash:core
64770 drwx 4096 Jul 8 2019 23:12:37 -04:00 modules
32398 -rw- 1 Jul 13 2022 10:57:50 -04:00 .callhome
IDF_2#dircrashinfo:
% Bad IP address or host name% Unknown command or computer name, or unable to find computer address
IDF_2#dir crashinfo:
11 -rw- 0 Dec 31 1969 19:00:52 -05:00 koops.dat
36641 drwx 24576 Jul 13 2022 11:03:32 -04:00 tracelogs
12 -rw- 1125665 Dec 3 2019 08:16:57 -05:00 system-report_2_20191203-131655-UTC.tar.gz
13 -rw- 1027636 Dec 3 2019 09:21:29 -05:00 IDF_2_2_RP_0_trace_archive_0-20191203-142126.tar.gz
14 -rw- 565863 Jul 1 2022 09:00:23 -04:00 IDF_2_2_RP_0_trace_archive_0-20220701-090021.tar.gz
825638912 bytes total (776753152 bytes free)
IDF_2#exit
