2 Vlans on 2 switches and 1 router - help
garbis1000
Hi there.
im trying to configure 2 vlans with the same name, one on each switch so they can "ping". but this doesn't work. I have tried with dot1q and trunk but I can't find any solution. Maybe it's because I'm new to this. If you could help me I would be very grateful. I leave the file and an image. the vlans are for the cameras.
First, I would avoid using the VLAN1 default for any other purpose..
Try below config :
SwitchIE
create vlan 10 (this can be voice vlan)
config t
vlan 10
no interface Vlan1
interface Vlan10
ip address 192.168.1.62 255.255.255.192
no shutdown
ip default-gateway 192.168.1.2
use below example connecting to router port and other ports
interface FastEthernet0/X
switchport mode access
switchport access vlan 10
no shutdown
SwitchIE
create vlan 20
config t
vlan 20
no interface Vlan1
interface Vlan20
ip address 192.168.1.126 255.255.255.192
no shutdown
ip default-gateway 192.168.1.66
use the below example connecting to the router port and other ports
switchport access vlan 20
no shutdown
BB
9 Replies 9
balaji.bandi
Couple of questions to clarity here :
1. Router outside to ISP having same subnet as Lan ?
2. what is the Lan subnet mask ? and what gateway ?
Since the router in the between, you can not extend the Layer 2 VLAN via Router (unless you configure BVI Interface.)
Instead i would suggest to connect link between switches configure as Trunk in the interface config, that may  fix your issue, to have communication between
BB
Hello, thanks for answering
No the router in the "isp" cluster is only there as a connection. It is to explain in an exhibition how the internet that reaches the company works. and regarding the configuration of the mask and all that is the following.
Router to SwitchIE: 192.168.1.2 255.255.255.192
Router to SwitchOA: 192.168.1.66 255.255.255.192
Ok so, when you refer to connecting the switches, do you mean without disconnecting them from the router?
If the switch acting as Layer 2, and router is configured as mentioned IP address and ip routing enabled both the side communication should work as expected.
One thing not clear in this diagram what is the IP address between Router to IP in the RED link ?
can you attached show run  information from router and both the switches to understand what configured.
BB
If you see some interfaces with "voice vlan" it is because I programmed the phones with dhcp so that it automatically assigned the IPs and I excluded the rest of the IPs that I placed statically in the rest of the devices.
i can only look if you can post a show run (in a text file) I am not able to read the images correctly
BB
Router
Spoiler
no service timestamps debug datetime msec
hostname RouterSP
ip dhcp excluded-address 192.168.1.0
ip dhcp excluded-address 192.168.1.1
ip dhcp excluded-address 192.168.1.2
ip dhcp excluded-address 192.168.1.3
ip dhcp excluded-address 192.168.1.64
ip dhcp excluded-address 192.168.1.65
ip dhcp excluded-address 192.168.1.66
ip dhcp excluded-address 192.168.1.67
ip dhcp excluded-address 192.168.1.4
ip dhcp excluded-address 192.168.1.5
ip dhcp excluded-address 192.168.1.7
ip dhcp excluded-address 192.168.1.8
ip dhcp excluded-address 192.168.1.9
ip dhcp excluded-address 192.168.1.10
ip dhcp excluded-address 192.168.1.11
ip dhcp excluded-address 192.168.1.12
ip dhcp excluded-address 192.168.1.13
ip dhcp excluded-address 192.168.1.68
ip dhcp excluded-address 192.168.1.69
ip dhcp excluded-address 192.168.1.70
ip dhcp excluded-address 192.168.1.71
ip dhcp excluded-address 192.168.1.72
ip dhcp excluded-address 192.168.1.73
ip dhcp excluded-address 192.168.1.74
ip dhcp excluded-address 192.168.1.75
ip dhcp excluded-address 192.168.1.76
ip dhcp excluded-address 192.168.1.77
ip dhcp excluded-address 192.168.1.78
ip dhcp excluded-address 192.168.1.79
ip dhcp pool voice
network 192.168.1.0 255.255.255.192
default-router 192.168.1.2
option 150 ip 192.168.1.2
ip dhcp pool service
network 192.168.1.64 255.255.255.192
default-router 192.168.1.66
option 150 ip 192.168.1.66
ip cef
no ipv6 cef
license udi pid CISCO2811/K9 sn FTX1017262S-
spanning-tree mode pvst
interface FastEthernet0/0
ip address 192.168.1.2 255.255.255.192
duplex auto
speed auto
interface FastEthernet0/1
ip address 192.168.1.66 255.255.255.192
duplex auto
speed auto
interface GigabitEthernet0/3/0
ip address 10.0.0.2 255.255.255.252
interface Vlan1
no ip address
shutdown
ip classless
ip route 0.0.0.0 0.0.0.0 10.0.0.1
ip flow-export version 9
telephony-service
max-ephones 10
max-dn 10
ip source-address 192.168.1.66 port 2000
auto assign 1 to 10
ephone-dn 1
number 7820
ephone-dn 2
number 7821
ephone-dn 3
number 7822
ephone-dn 4
number 7823
ephone-dn 5
number 7824
ephone-dn 6
number 7825
ephone-dn 7
number 7826
ephone-dn 8
number 7827
ephone 1
device-security-mode none
mac-address 00D0.FF18.3BA4
type 7960
button 1:1
ephone 2
mac-address 0003.E4D4.4482
type 7960
button 1:2
ephone 3
mac-address 0007.EC7B.C773
type 7960
button 1:3
ephone 4
mac-address 00E0.F7B9.5B54
type 7960
button 1:4
ephone 5
mac-address 00E0.F901.E92B
type 7960
button 1:5
ephone 6
mac-address 0002.172A.8A9B
type 7960
button 1:6
ephone 7
mac-address 0060.5C67.2C67
type 7960
button 1:7
ephone 8
mac-address 0001.4230.B84E
type 7960
button 1:8
ephone 9
mac-address 0004.9A90.0377
line con 0
line aux 0
line vty 0 4
login
end
SwitchOA
Spoiler
hostname SwitchOA
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
switchport voice vlan 1
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface Vlan1
line con 0
line vty 0 4
login
line vty 5 15
login
end
SwitchIE
Spoiler
hostname SwitchIE
interface Vlan1
line con 0
line vty 0 4
login
line vty 5 15
login
end
Try below config :
SwitchIE
config t
vlan 10
no interface Vlan1
interface Vlan10
no shutdown
no shutdown
SwitchIE
create vlan 20
config t
vlan 20
no interface Vlan1
interface Vlan20
no shutdown
no shutdown
BB
I have opened your file, and I have full connectivity. From which source IP to which destination IP can you not ping ?
Source IP: 192.168.1.5
Destination IP: 192.168.1.67
Success or Failure: S/F
Hey.
Yes, you can ping any host. The problem is why I started the post because I want to create a vlan for the cameras and the server "vlan 10".
I can create a vlan on each switch with the same name but this does not guarantee that the SwitchIE cameras can ping the SwitchOA cameras. Actually that is my question.
What commands should I use?
