2 Vlans with 25 devices each with same network
chandra_rc16
Level 4
Level 4
Can someone please help me for the below scenario ?
Assume that i have 50 PCs in my organization and only two groups of people working called as Voice & Non-voice. And the IP addressing i want to use is
10.0.0.0/26.
For voice group i have assigned IP address range from : 10.0.0.1/26 to 10.0.0.25./26
For non-voice group i have assigned IP address range from: 10.0.0.26/26 to 10.0.0.50/26
I have placed all the voice PC's in Vlan10 and nonvoice PCS's in Vlan20.
And i have assinged 10.0.0.62/26 for my router.
And i have assigned 10.0.0.55/26 for the Vlan10
When i'm trying to assign 10.0.0.56/26 for the Vlan20.. it is alerting me that it overlaps.
Can someone please let me know where i'm wrong ?
Chandu
Regards, Chandu
vmiller
Level 7
Level 7
You are splitting the /26 into 2 /27's. you need to adjust your mask accordingly
subnet               mask                   inverse         size          host range                    broadcast
10.0.0.0         255.255.255.224    0.0.0.31         30    10.0.0.1  to  10.0.0.30      10.0.0.31
10.0.0.32       255.255.255.224    0.0.0.31         30    10.0.0.33  to  10.0.0.62    10.0.0.63
9 Replies 9
vmiller
Level 7
Level 7
Thank you.
But i have a doubt. So when we are planning IP Addressing. Do we need to consider every VLAN as a host ? Because we need to assign an IP Address to it.
And why the VLAN's need Layer 3 IP address. Because while we configure "router on a stick" we give the command "encapsulation dot1Q ". Can't the routing can be done only with the Vlan ID ?
And even we have to assign an IP address to the sub-interface. So it seems like in planning IP Addressing we need to think of both the vlan ip and the ip for the routers subinterface. Aren't we wasting two IP addresses ?
And which address will network admins usually assign to the VLAN's ? Will they pick in randomly or first address or last address like that ?
Thanks in Advance.
I'm new to networking, please don't mind if my question seems to be silly.
Chandu
Regards, Chandu
Routers use layer 3 addressing to make routing decisions. VLAN ID is a layer 2 tag. When the ethernet frame arrives at your router interface with a VLAN tag the tag is stripped away before it is sent to the actual routing engine.
You don't have to have a subnet for each VLAN but it is best practice and in 99 out of 100 times it is the way to go. Yes you will use one more IP-address, but are you really short on RFC 1918-addresses?
To follow up on Simens reply.
If Possible, consider each VLAN a subnet. it removes confusion (for you) in that sense, each VLAN needs a route to the rest of the world... an IP address. which should be in the same subnet as the VLAN.
Take my first example above, I would make my router interface the 10.0.0.1 address, It will handle routing for the rest of the subnet.
chandra_rc16
Level 4
Level 4
Thanks Simen and vmiller for clearing my confustion.
vmiller i'll implement your example and ping you for any difficulties.
Thank you both.
Regards, Chandu
No Problem.
1. Keep things simple; 1 vlan = 1 subnet.
     within the subnet/vlan use the first host for what ever routed interface you use.
     save a couple of addresses for printers, use the same range for each user subnet
          first host - router 9or sub interface
          hosts 2 thru 5 - printers
          5 and above  anything else in the vlan.
just get one to work for now....
chandra_rc16
Level 4
Level 4
Thank a lot. It worked for me.
And is it neccessay for us to remeber the RFC numbers to pass CCNA R&S exam ?
Chandu
Regards, Chandu
Focus on fundamentals. quoting RFC's chapter line and verse is pretty meaningless.
1. Subnetting you need to know this backwards and forwards. be capable of working subnetting problems
     with pencil & paper.
2. understand the mechanics of routing, arp lookup, and basic switch operation.
3. understand the OSI model and how it relates to internetworking issues.
There is a blueprint on the ciso site.
chandra_rc16
Level 4
Level 4
Thanks a lot.
Regards, Chandu
