/20 subnet question
njnetwork
Community Member
Hello all,
I'm trying to answer the following question:
What is the next subnet ID for the IP address: 172.29.48.0 /20
/20 block size is 4096 addresses (not subtracting 2 here, because we're not calculating hosts)
How do I get from 172.29.48.0 to the next network address of 172.29.52.0? The network blocks are incrementing by 4 in the third octet, but I don't understand why. I've scoured the internet trying to answer this question, and am not finding what I need. Chat GPT was also unhelpful.
Any clarification would be greatly appreciated.
2 Accepted Solutions
4096 hosts
each netework bit give you 255 hosts
4096/255 host = 16
that why you see the network-network interval is 16
Joseph W. Doherty
"How do I get from 172.29.48.0 to the next network address of 172.29.52.0?"
You don't, if you're using /20s.  The next network address, for a /20, would be 172.29.64.0.
172.29.52.0/20 is within 172.29.48.0/20, i.e. it's a host address.
BTW, another way to understand the situation, is "watch" the binary values.
A /20 divides the 32 bit IP address as: nnnnnnnn.nnnnnnnn.nnnnhhhh.hhhhhhhh.
In the third octet, the last network bit is the 4th bit, of 8.  I.e. binary 10000 = 16 decimal, which is why you see, in @MHM Cisco World first posting, the 3rd octet jumping by 16s.
"/20 block size is 4096 addresses (not subtracting 2 here, because we're not calculating hosts)"
Yes, that's correct, each /20 contains an IP address range of 4,096 because the largest host number, in binary, is 1111 1111 1111 or 4,065 decimal, plus counting zero, provides 4,096 numbers.
6 Replies 6
njnetwork
Community Member
Thank you for you response, but this is not helpful. I know how to use a subnet calculator. I'm trying to understand what calculation is used to increment subnets this large. I need the why, not the answer.
4096 hosts
4096/255 host = 16
Joseph W. Doherty
Thank you! This is super helpful.
You're most welcome.
One of IPv4's mysteries, to me, is why IP addresses are represented as a dot-decimal.  Maybe because it was seen to go well with Classful addressing?
Certainly makes many struggle when you need to use ACLs and/or subnet/supernet.
