2511 reverse telnet
cisco steps
Hi again . now I was able to get from comm-server 2511 to 2610 when I canfigured the loopback0.. now I wan to getback to 2511 com-serv its says on the doc that I need to do Ctrl+shift 6, twice// I did but I am still on the R1 PROMT
do I need to config a loopback0 on 2610 so it will go back to 2511.. ?
2 Accepted Solutions
CSCO10892433
Level 4
Level 4
Type "Ctrl+shif-6" then "X"
SSLIN
Please follow these steps
1. Press the keys "Ctrl","shift","6" at the same time.
2. Release the above keys.
3. Hit the key "x"
Hope this works. If not, let me know.
SSLIN
8 Replies 8
CSCO10892433
Level 4
Level 4
SSLIN
you mean hit the key Ctrl+shif-6 the letter X or type it ..
3. Hit the key "x"
SSLIN
thanks will try and let you know, not near the lab today/
I was able to got from 2511 to R1.. I did what its says .. but i does not work.
R1#x
% Ambiguous command: "x"
R1#xR1#x
R1#show session
% No connections open
R1#show sessions
I was able to firuge it out.. I guess I ahve to be on enable user mode.. then apply the command ..
Thanks for the help
R1#disable
R1>
2511sw#
Hi, ocporbust
That sounds strange. I had used this command for thousands times. It worked no matter the router was on user mode or exec mode.
Would you please try it again?
SSLIN
sorry for the delay of my response, I did it this time and it did work from the ex mode.. Thanks
