2600 Flash SIMM Upgrade Problem
r_berana
Hi NetPros. I added 8MB flash - SM732C2000AS-12 but after switching on the router and checking the memory status it is not reflecting the additional memory, it is still showing 16MB of flash instead of 24MB. I have 6 8MB flash and i checked all of them but no luck. Please help.
ahmednaas
Level 4
Level 4
Is it a 2600 or a 2600xm?
The 2600 series max flash is 16 mb
the model is 2621XM.
I think the Flash you have is for the 2600 series. The 2600XM series accepts only 16mb or 32mb 3.3 volt flash. the 2600's is 5 volt.
Amit Singh
Please have a look at the link below.Go through it and it should help you find out the exact problem you are facing:
http://www.cisco.com/en/US/products/hw/routers/ps259/products_installation_guide_chapter09186a008007e1fb.html#wp93135
HTH,
-amit singh
