2600 Router w Cable Modem
Luis Diaz
Hey All
I have a cable modem with my 2600 Router and i have a little speed problem when im going out to the web via my F0/0.. according to regular speed test sites my speed is around 20mbps but when i hook up to my modem directly i get a solid 40mbps.. now ive changed my Cat 6 cable from my modem to my router and this are my settings in the router
interface FastEthernet0/0
description Modem
ip address 192.168.0.2 255.255.255.0
ip nat outside
ip virtual-reassembly
speed 100
full-duplex
interface FastEthernet0/1
description R1 to SW1
ip nat inside
speed 100
full-duplex
Details..
FastEthernet0/0 is up, line protocol is up
  Hardware is AmdFE, address is 000d.29a0.a480 (bia 000d.29a0.a480)
  Description: Modem
  Internet address is 192.168.0.2/24
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, 100BaseTX/FX
  Last input 00:00:03, output 00:00:01, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 454000 bits/sec, 51 packets/sec
  5 minute output rate 164000 bits/sec, 38 packets/sec
     43336 packets input, 50257913 bytes
     Received 68 broadcasts, 0 runts, 0 giants, 0 throttles
     153 input errors, 45 CRC, 21 frame, 7 overrun, 101 ignored
     0 watchdog
     34477 packets output, 17800631 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
     0 unknown protocol drops
     6 lost carrier, 0 no carrier
FastEthernet0/1 is up, line protocol is up
  Hardware is AmdFE, address is 000d.29a0.a481 (bia 000d.29a0.a481)
  Description: R1 to SW1
  Internet address is 192.168.1.1/24
  Last input 00:00:00, output 00:00:00, output hang never
  5 minute input rate 151000 bits/sec, 33 packets/sec
  5 minute output rate 411000 bits/sec, 47 packets/sec
     36229 packets input, 18117969 bytes
     Received 572 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog
     45394 packets output, 50061986 bytes, 0 underruns
     86 unknown protocol drops
     11 lost carrier, 0 no carrier
I see some drops and lost carriers but not sure what those might mean.. ideas?
Thank you all!
Leo Laohoo
Errrr ... With CEF enabled, the 2600 router (if memory serves me correct) can process up to 18 mbps of data.  The value is expressed in HALF duplex and no encryption.
So, if you have a 40 mbps cable modem ...
Did you measure the speed at different times to get a reading from router and modem?
