Error, Packets dropped on LAN interface on Router
ciscoroyzhang
Hi all
have exprience some network performace issue, on one of router's LAN interface, sh int fa0/0 as following:
FastEthernet0/0 is up, line protocol is up
  Hardware is MV96340 Ethernet, address is 0013.8083.6b38 (bia 0013.8083.6b38)
  Description: CPGRDAC LAN
  Internet address is 10.109.51.25/24
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
     reliability 252/255, txload 1/255, rxload 1/255
  Keepalive set (10 sec)
  Half-duplex, 100Mb/s, 100BaseTX/FX
  Last input 00:00:00, output 00:00:00, output hang never
  Input queue: 0/800/1/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  30 second input rate 57000 bits/sec, 55 packets/sec
  30 second output rate 564000 bits/sec, 68 packets/sec
     491981360 packets input, 280920410 bytes
     Received 10681245 broadcasts, 219931135 runts, 0 giants, 1 throttles
     232252247 input errors, 12269198 CRC, 51914 frame, 0 overrun, 0 ignored
     0 watchdog
     470638181 packets output, 2577702497 bytes, 0 underruns
     280773 output errors, 16724512 collisions, 0 interface resets
     2203107 unknown protocol drops
     0 babbles, 280679 late collision, 0 deferred
     0 lost carrier, 0 no carrier
thnaks in advance,   Roy
ebarticel
Level 4
Level 4
Your Fast Ethernet is configured on half-duplex looking at the output
    "Half-duplex, 100Mb/s, 100BaseTX/FX"
to fix
interface fastethernet0/0
duplex full
speed 100
Hope this helps
Eugen
Krishnendu AR
Hi Roy,
Did you check the speed and duplex at the other end ? It should be matching to this side.
Krishna
viswamin
since the collusion is high, looks like there is a duplex mismatch. can you pls check that
-Vijay
ebarticel
Level 4
Level 4
to fix
duplex full
speed 100
Hope this helps
Eugen
