2621 router - wrong config register change - big problem
chrissiems00
i'm using this 2621 router in my lab.  I fat fingered the config register value i was changing to try and trouble shoot a flash problem.  i changed it to 2201, and reset the box.  now the output is all garbled and not readable.
Is there a way to fix this? i believe that config-reg value is not supported and that's why the output is all garbled.
thanks for any info - i'm sure it's not too common.
glen.grant
   You have changed the console speed on the router.  Play with your terminal emulator (Tera Term , Putty etcc.)  starting at 2400 bps and increment by 2400 bps increments until you find the correct speed that the router is running at now .  If you want to know  what 2201 is then download a config register calculator  and it will tell what speed you changed it to with that value.  Try 2400, 4800,19200,38400 etcc.
YEA!!! 19200 was the speed! Thanks so much!
On Thu, Jun 17, 2010 at 12:57 PM, glen.grant <
