2811 compact flash disk
mike.moyer20001
My cisco 2811 compact flash card went out and I bought a new one. And my router is stuck in rommon and I can not format compact flash. And some one said to format on the PC and then I need to copy the system file from a working compact flash disk.
Hello
I would say if this didnt work try FAT16
I am assuming you have a external card reader?
Then take a flash card from another router ( if applicable) and copy the bin flie over to the new card.
@karsten -  FYI - I have had in the past to format my 2811 flash(s)  FAT16 as I found FAT32 didnt work for me.
res
Paul
Kind Regards
Paul
5 Replies 5
You can format the card with FAT32 and directly copy the IOS-image to the card. With that you can boot and start to paste in a backup of your config. Be aware that the router might not recognize CF-cards with big capacity. At least 1GB cards are working here without problems.
Hello
res
Paul
Kind Regards
Paul
I was pretty confident that it has to be FAT32, but now I'm doubtful ... I'll look at my 2811 when I'm again in the office.
mike.moyer20001
where do you find source to get another working router to copy the the system file. And after format the CF card in window or linux. You still need system file to put your ISO on CF.
Hello
If you dont have access to another working router running the same ios that is to be used on yor new flash card, then you can download it from CCO providing you have privleges to do so.
res
Paul
Kind Regards
Paul
