2811 configuration
franktuck
Community Member
Can I use teh compact flash from one router to configure another? They are both the same make and model.
Franklin,
Yes,You can
Toshi
Toshi,
Thanks for your reply
What are the steps?
Leo Laohoo
From Router 1:
write mem
copy nvram:startup-config flash:startup-config
Move CF from Router 1 to Router 2
copy flash:startup-config running-config
write memory
Does this help?
Hi Leo,
Is it safe to remove the CF from the router while it's running?
