2811 connection problem with T-marc switch
jeffhouston
I have a Cisco 2811 router functioning as LAN router for an Ethernet handoff from my ISP. The connection is supposed to be 25MB yet all I can get is 8 at best and the speed varies from .18 to 7.9 up and down. Neither interface shows any errors but I have tried port negotiation settings but nothing seems to work. I installed a different 2811 router with the same but stripped down config so completely different hardware.
When I plug a PC into the ISP port the connection speed is fast like it should be but  when I go through the routers LAN ports the speed is variable and problematic but no interface errors. I have tested the router with nothing on the "inside" interface but the same PC that works fine directly connected. The problem gets worse the more data goes through it. Light ping tests respond quickly and well but increaser the ping size and the issue shows but still no errors!
The ISP switch is a Telco-Systems T-Marc 280, and they have no information or help other than to say this is my issue and because I can get full connection speed without using either router I tend to agree.
Does anyone have any ideas what could be going on? Is there any known issues between certain switch ports that have compatibility issues? Issues that would not show up as errors on interface? I have an open ticket with TAC and they cannot find any problems with the router and resorted to send me another one but since I have a completely different hardware 2811 I doubt it will make a difference.
Any advice, suggestions, or information that would help resolve this would be greatly appreciated.
Thanks!   connection
8 Replies 8
devils_advocate
Level 7
Level 7
Hi Jeff
You say you have installed a different 2811 router you didn't say (as far as I can make out) whether the speed improved?
Could you post the Router configuration?
What I wanted to say was that the 2nd router had the same issue as the 1st or completely different hardware's behavior was identical to the original router and no speed improvement.
The connection I am trying to use is a new a Fiber hand off that is delivered to me from my ISP as Ethernet from their MPLS. I currently have a 3 T1's I multilink together to get 4.5MB (from the same ISP) and both connections go to my main office in another city.
So I will post two router configs: 1st is from the second router I used to test hardware being the issue of the 1st: ( it is currently up on another port my ISP enabled for me to test)
Building configuration...
Current configuration : 1453 bytes
version 12.4
hostname Cedar-Router
boot-start-marker
boot-end-marker
logging message-counter syslog
no logging console
no aaa new-model
clock timezone MDT -7
dot11 syslog
ip source-route
ip cef
no ipv6 cef
!voicce-card 0
!username **** privilege 15 secret 5 $1$IPwk$QuNOxuNP/cfokd2ty5IGY/
archive
 log config
  hidekeys
interface FastEthernet0/0
 description Cedar Main LAN
 ip address 192.168.121.1 255.255.255.0
 duplex auto
 speed auto
interface FastEthernet0/1
 description Cedar Fiber to MPLS to STG
 ip address 192.168.250.34 255.255.255.252
 duplex auto
 speed auto
interface Serial0/0/0
 description Horizon House West T1
 ip address 192.168.149.45 255.255.255.252
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.250.33
ip route 192.168.250.20 255.255.255.252 192.168.250.33
ip http server
no ip http secure-server
!snmp-server community public RO
snmp-server enable traps tty
snmp-server enable traps envmon
snmp-server enable traps syslog
control-plane
!mgcp fax t38 ecm
mgcp behavior g729-variants static-pt
line con 0
 login local
line aux 0
line vty 0 4
 privilege level 15
 login local
line vty 5 15
 privilege level 15
 login local
scheduler allocate 20000 1000
end
This is the router I am currently using but keep kin mind I have reverted the configuration IP routing back to work with the T1's since the MPLS is not stable enough to run with confidence.
Current configuration : 5240 bytes
version 12.4
service sequence-numbers
hostname Cedar-Main
boot-start-marker
boot-end-marker
logging buffered 51200
no logging console
enable secret 5 $1$b1Df$mwQDQFburoSyg1K7v8vha.
no aaa new-model
clock summer-time MDT date Apr 6 2003 2:00 Oct 26 2003 2:00
no network-clock-participate wic 0
no network-clock-participate wic 1
no network-clock-participate wic 2
no network-clock-participate wic 3
dot11 syslog
ip source-route
ip cef
ip dhcp smart-relay
ip dhcp relay information trust-all
ip domain name SBHC.local
no ipv6 cef
!voice-card 0
crypto pki trustpoint TP-self-signed-196736342
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-196736342
 revocation-check none
 rsakeypair TP-self-signed-196736342
crypto pki certificate chain TP-self-signed-196736342
 certificate self-signed 01
  3082024B 308201B4 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31393637 33363334 32301E17 0D313530 31303732 32323731
  365A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F
  532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3139 36373336
  33343230 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100
  E8946088 70C1C76D F14EABE8 2AA12082 FA7F9C11 DC87827A DA8A2E25 BDDF86A2
  6D831630 5EF94A7A 402A41E6 78753015 42305944 D9EBEBC6 E498FD04 BD3AFD62
  8D1B787D 55D91542 35FA08A4 DAE2AEBE 099128AF 794FAEFB 144C97C6 0A81FAEF
  0190B085 AC608E95 16705948 BC4D7465 BBA9D064 C95B1564 A770A71C E9E3FD3F
  02030100 01A37530 73300F06 03551D13 0101FF04 05300301 01FF3020 0603551D
  11041930 17821543 65646172 2D4D6169 6E2E5342 48432E6C 6F63616C 301F0603
  551D2304 18301680 14941548 A39D83D1 46A69E2D 57374488 05DB67CE 91301D06
  03551D0E 04160414 941548A3 9D83D146 A69E2D57 37448805 DB67CE91 300D0609
  2A864886 F70D0101 04050003 81810016 B41168A0 8DC0095E C01CE90B 3A9511F3
  E406481C 8747E142 DE611CA7 ED9088E1 9C6EAF1C 57B5D50D D39A54E7 C264D866
  713F1468 D92CFB21 4EF8FE16 368899D4 F6C24BC5 A4B25E36 4BA0DF7F 48A52826
  E0F01DBA 9DDBFC24 34DF2A18 2C9B01B9 2EAD66D6 51701546 1A74038E E524F655
  CA0CAFC8 C7F6373B 7C2F1E72 55F7A5
        quit
username **** privilege 15 secret 5 $1$CGqb$jXHCTwWa6P74L8TwwhF2r/
archive
 log config
  hidekeys
controller T1 0/0/0
 channel-group 0 timeslots 1-24
 description Frame-Relay to HDS & STG
controller T1 0/0/1
 fdl ansi
 channel-group 1 timeslots 1-24
 description Multilink T1 to SG
controller T1 0/1/0
 description T1 to Milford
controller T1 0/1/1
 description T1 to Horizon House
controller T1 0/2/0
 fdl ansi
 description T1 Multilink
controller T1 0/2/1
 fdl ansi
controller T1 0/3/0
controller T1 0/3/1
!interface Multilink1
 description TRi T1 Group Mutilink
 ip address 192.168.149.42 255.255.255.252
 ppp multilink
 ppp multilink group 1
 description Cedar Main LAN$ETH-LAN$
 ip address 192.168.132.1 255.255.255.0
 ip helper-address 192.168.130.10
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 duplex auto
 speed auto
 no cdp enable
 no mop enabled
 description Cedar Fiber to STG Gateway
 ip address 192.168.250.17 255.255.255.252
 duplex auto
 speed auto
interface Serial0/0/0:0
 description NOT USED
 ip address 192.168.149.13 255.255.255.252
 shutdown
interface Serial0/0/1:1
 description T1 #1 to Tri-T1 Multilink
 no ip address
 ip directed-broadcast
 encapsulation ppp
 ppp multilink
interface Serial0/1/0:0
interface Serial0/1/1:0
 description Horizon T1
 shutdown
interface Serial0/2/0:1
 description T1 #2 to Tri-T1 Multilink
 no ip address
 encapsulation ppp
 ppp multilink
interface Serial0/2/1:1
 description T1 #3 to Tri-T1 Multilink
 no ip address
 encapsulation ppp
 ppp multilink
ip route 0.0.0.0 0.0.0.0 192.168.149.41
ip route 192.168.135.0 255.255.255.0 192.168.132.226
ip route 192.168.137.0 255.255.255.0 192.168.149.46
ip route 192.168.139.0 255.255.255.0 192.168.132.226
ip http server
ip http authentication local
ip http timeout-policy idle 60 life 86400 requests 10000
control-plane
!banner motd ^CAUTHORIZED ACCESS ONLY!^C
line con 0
 login local
line aux 0
line vty 0 4
 privilege level 15
 login local
 transport input telnet ssh
line vty 5 15
 privilege level 15
 login local
end
The best I can come up with to this point is install the router Cisco TAC sent me to replace the original or insist my ISP install a different switch other than the T-Marc. I have 3 other Fiber connections with the same ISP at different locations but only to 10MB with the same type of 2811 or 2801 router with no issues. The difference is my ISP uses a Alcatel switch not a T-marc.
Any ideas or information to help me solve this would be greatly appreciated!
Jeff
Jeff,
2811 is not very fast router but it should not be that slow (8Mb).  See link below and look at the 2811 section.
http://www.cisco.com/web/strategy/docs/gov/IPv6perf_wp1f.pdf
Instead of replacing your existing router with another router, for test purpose can you use a switch (2960, 3560, etc..) instead and perform the same test?
Hi Reza,
Unfortunately I don't have a functioning switch of that caliber available to me but I think I see where you're going with that; to see if how a different piece of equipment handles the connection?
All I have on the shelf is a Small Business class SF300. Do you know if that would route? Or work? Or I could try a router designed for home use at least to test with.
Jeff,
I have never used the SF300 series before but looking at the data sheet it appears that it can do static routing.  I have a feeling the issue is not T-Marc equipment but rather the 2911 and if you connect a switch to the T-marc you will see improvement.
One other thing, most providers want the customers to hard set the speed on their ports.  Have you done it and test it?
data sheet:
Static routing/Layer 3 switching between VLANs: This capability allows you to segment your network into separate workgroups and communicate across VLANs without degrading application performance. As a result, you can manage internal routing with your switches and dedicate your router to external traffic and security, helping your network run more efficiently.
http://www.cisco.com/c/en/us/products/collateral/switches/small-business-smart-switches/data_sheet_c78-610061.html
Hi Reza,
Thanks for your post.
I have tried changing the Speed and Duplex on the interface to static settings but it didn't make a difference.
I could use my switch instead of the router but as I mentioned in my original post; I have 3 other similar connections with the same ISP into the MPLS at different locations in my area, each using the same or similar 2811 router and I don't have any of these issues at all. The ONLY difference is the T-marc switch. Each of the other 3 location have an Alcatel-Lucent 12 port switch.
If in fact the switch was the difference how could I get or program my 2811 to be compatible and communicate better with the T-Marc?
I will travel back on site in a day or two and try the new router TAC sent me and then if the problem persists then I'll install a switch and see what happens.
Jeff
The problem I had was that any Cisco or possibly any other device when plugged into the Telco Systems T-Marc switch had incredible latency. There was something about the way a PC's Ethernet port saw the connection vs. a router or switch port that they just didn't get along but the PC would.
I suspect there was a fault in the T-marc which caused this but after installing a different switch sent by my ISP the connection lit up and worked as it should.
My last attempt was Reza's suggestion of using my Catalyst switch rather than the router. when I had the same result with the switch I was convinced something had to be wrong with my SIP's T-Marc switch which ended up being the problem.
Thanks for the input, in the end, like most things in life I learned a lot by struggling through this problem, my hair is a little grayer, and blood pressure up slightly but I'm a slight fraction of a degree smarter :)
Thanks!
Jeff,
Thanks a lot for the detail feedback.
I am glad you figured it out.  Very interesting issue.
Question:
What is the 2811 speed now after the ISP switch replacement?
Reza
