2811 Router DHCP static binding not working
geraldmurphy1
Good morning,
I am unable to get static binding working with the following config.  The IP I am trying to assign is listed in the excluded range.  Is this config correct?
ip dhcp excluded-address 172.16.2.1 172.16.2.32
ip dhcp pool staff
   network 172.16.2.0 255.255.255.0
   dns-server 74.22.134.3
   default-router 172.16.2.1
   lease 0 3
ip dhcp pool static
   host 172.16.2.23 255.255.255.0
   client-identifier 00c0.17b1.27c1
Cheers,
Gerald
Mark Malone
Hey Looking at that you CID is wrong should start with 01. for ethernet media when using client ids if I remember correctly not a direct mac config needs to be like 0100.c017.b127.c1 or else use the full CID  from the debug output that's provided when you debug fro the client ID ---- the real long HEX number
Adding the 01 at the start fixed the issue.  Thanks Mark.
Cheers,
Gerald
ah great :)
