2811 Router need interface specific routes and gateway
Matt.Fields
I am trying to have a diffent default-gateway and routes for the each of the two FastEthernet interfaces on my Cisco 2811 Router
This is currently how it looks:
interface Multilink1
ip address 67.xxx.xxx.126 255.255.255.252
ppp multilink
ppp multilink fragment disable
ppp multilink group 1
interface Serial0/0/0
description Quest Internet T1
no ip address
encapsulation ppp
no keepalive
no fair-queue
ppp multilink
no shutdown
interface Serial0/1/0
no ip address
encapsulation ppp
no keepalive
no fair-queue
ppp multilink
no shutdown
interface FastEthernet0/0
ip address 69.xxx.xxx.65 255.255.255.224
speed auto
full-duplex
no shutdown
speed auto
interface FastEthernet0/1
ip address 192.168.21.1 255.255.255.0
no shutdown
duplex auto
speed auto
For anything traveling though the FE0/1 interface, I want to use the below routes:
ip route 0.0.0.0 0.0.0.0 192.168.21.2 (Back to PIX, then gets filtered by Websense)
ip route 172.16.0.0 255.252.0.0 192.168.21.4
ip route 172.20.0.0 255.252.0.0 192.168.21.4
ip route 192.168.33.0 255.255.255.0 192.168.21.4
For anything traveling though the FE0/0 interface, I want to use the below routes:
ip route 0.0.0.0 0.0.0.0 67.XXX.XXX.125 (WAN Gateway back to ISP)
I would like to segragate the two interfaces, as if they were different routers.
Is this possible?
spremkumar
Level 9
Level 9
Hi Matt
You can try configuring the below commands.
ip route 0.0.0.0 0.0.0.0 192.168.21.2 interface FastEthernet0/1
ip route 172.16.0.0 255.252.0.0 192.168.21.4 interface FastEthernet0/1
ip route 172.20.0.0 255.252.0.0 192.168.21.4 interface FastEthernet0/1
ip route 192.168.33.0 255.255.255.0 192.168.21.4 interface FastEthernet0/1
ip route 0.0.0.0 0.0.0.0 67.XXX.XXX.125 interface FastEthernet0/0
also i see no nat enabled in your config..
If you are trying to access internet using this you need to create nat configs accrodingly.
regds
mheusinger
Level 10
Level 10
this can be achieved with the help of a VRF, which works like a separate router:
ip vrf FE00
rd 65000:1
ip vrf forwarding FE00
ppp multilink
no ip address
encapsulation ppp
no keepalive
no fair-queue
ppp multilink
no shutdown
no ip address
encapsulation ppp
no keepalive
no fair-queue
ppp multilink
no shutdown
speed auto
full-duplex
no shutdown
speed auto
no shutdown
duplex auto
speed auto
ip route vrf FE00 0.0.0.0 0.0.0.0 67.XXX.XXX.125
There will not be any connectivity between FE0/0 and FE0/1
Hope this helps! Please rate all posts.
Regards, Martin
