2811 simple script not working Advice please
1885
We just started working with Cisco routers and switches in our learning lab. (school)
We want to get a 2811 Router to do something simple.  Just route two private networks 192.168.1.1/24 and 192.168.2.1/24
Our script runs in Packettracer 7.1 but not on the actual router.
Here is the script we are using with level 1 switches connected and static ip addresses.
Router#erase startup-config
Router#enable
Router#configure terminal
Router(config)#interface FastEthernet 0/0
Router(config-if)#ip address 192.168.1.1 255.255.255.0
Router(config-if)#no shutdown
Router(config)#interface fastEthernet 0/1
Router(config-if)#ip address 192.168.2.1 255.255.255.0
Router#show ip interface brief
Interface              IP-Address      OK? Method Status                Protocol
FastEthernet0/0        192.168.1.1     YES manual up                    down
FastEthernet0/1        192.186.2.1     YES manual up                    down
Vlan1                  unassigned      YES unset  administratively down down
This should work but it doesn't .  Any ideas?  We also installed new firmware.
This solved the simple problem.
ip route 192.168.0.0 255.255.255.0 192.168.1.0
ip route 192.168.1.0 255.255.255.0 192.168.0.0
Thank You!
R1#show running-config
Building configuration...
Current configuration : 1168 bytes
Last configuration change at 14:03:12 UTC Thu Dec 7 2017
version 15.1
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ipv6 cef
voice-card 0
license udi pid CISCO2811 sn FTX1107A4JP
redundancy
interface FastEthernet0/0
ip address 192.168.0.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
clock rate 125000
interface Serial0/0/1
no ip address
shutdown
clock rate 125000
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
mgcp profile default
line con 0
line aux 0
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end
7 Replies 7
Hi @1885
 What exactly is not working?
As per your config, you assigned IP address to two interface on the router, right. Two different network. This is correct for a router. Now, you router is able to pass traffic from network 192.168.1.0/25 to 192.168.2.0/24 and vice-versa.
 What are you trying to accomplish from here?
-If I helped you somehow, please, rate it as useful.-
This script did not work.  I need to assume there is something wrong with the router.
Thanks for the lines.
1885 (aka Craig)
Alright. Try to explain what is not work. I mean, are you trying to ping the router and it is not responding? What are you trying to do and is not working? Maybe I can help you if you explain the problem.
Julio E. Moisa
What is the purpose of your script? I see the changes have been applied, now the interfaces are up down it looks like a layer 2 problem, it could be cable or interface.
Could you please provide details about the objective of this configuration?
Thank you in advance.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Thank you for the post.
All we are trying to do is ping across router.
Right now we have the 2811 with level 1 switches on each side.
From node 192.168.1.2/24 to  ndoe 192.168.2.2/24
We will not be able to work on this until Wdnesday 12/6/17
Thank You
I am the student in question, and there has been a (not so) slight change.
We (I) hooked up the router to the "real world" (the room), and i was able to ping everything on our network from the router's CLI interface. I also swapped routers and the router is definitely not the issue, somehow the data needs to go "through"the router.
The original (and current) set up is a few computers hooked up to a Cisco 24-port switch (we'll have to check the model tomorrow).  Only one of the said computers is actually powered on, which is also the computer which i have hooked up via serial to the router's console port.  The switch is not programmed but indeed works.
The switch is set up with a crossover cable going from GigabitEthernet 0/1 on the switch to FastEthernet 0/1, while the real world connection is on FastEthernet 0/0 on the 2811.
Hope this helps.
1885
Thank You!
version 15.1
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ipv6 cef
voice-card 0
redundancy
duplex auto
speed auto
duplex auto
speed auto
no ip address
shutdown
clock rate 125000
no ip address
shutdown
clock rate 125000
no ip http server
control-plane
line con 0
line aux 0
line vty 0 4
login
transport input all
end
