2811 temperature issue
rleung2001
If the 2811 router reached over 40c, would it power down or would it goes to sleep mode?
spremkumar
Level 11
Level 11
I would suggest not to wait the router to go down totally or into sleep mode.
Though it may work fine for some more time its not recommended to run the box on the same condition.
Better to start taking measures to bring down the working temperature so that you can preserve the cards/ports installed in the router.
regds
Hi below mentioned specifications are self explainatory.
Environmental Specifications
Operating Temperature
32° to 104°F (0° to 40°C)
Non-Operating Temperature
-4° to 149°F (-20° to 65°C)
-40° to 158°F (-40° to 70°C)
Maximum Operating Temperature at Altitude
• 40°C @ sea level
• 31°C @ 6,000 ft (1800 m)
• 25°C @ 10,000 ft (3000 m)
Note: Derate 1.5°C per 1000 ft
• 40°C @ sea level
• 40°C @ 6,000 ft (1800 m)
• 30°C @ 13,000 ft (4000 m)
• 27.2°C @ 15,000 ft (4600 m)
Note: Derate 1.4°C per 1,000 ft above 6,000 ft
Operating Humidity
10 to 85% non-condensing
5 to 95%, non-condensing
http://cisco.com/en/US/prod/collateral/routers/ps5854/ps5882/product_data_sheet0900aecd8016fa68_ps5854_Products_Data_Sheet.html
