2911 Router 4 port Switch Module setup
jackh
I have a 2911 Router with a 4 port switch module (gigabitethernet0/0/0) that I want to have connected to my ISP to provide internet access, I currently have everything setup on the onboard ports (gigabitethernet0/0, 0/2, etc) which includes the ISP connection.
What I want is to be able to utilize the 4 port switch module and feed my internet through the module and keep my internal network on the onboard ports, the reason for this is cause I have all my VLANs configured on the port GigabitEthernet0/2.
Here is my setup.
Interface                       IP                    Purpose
GigabitEthernet0/0        10.0.1.10          Management
GigabitEthernet0/1        192.168.100.2   Internet
GigabitEthernet0/2        no ip address
GigabitEthernet0/2.1     172.17.1.10       Native VLAN
GigabitEthernet0/2.4     172.17.4.10       Development VLAN
GigabitEthernet0/0/0      not applicable   (want to implement for internet)
Anyone have any ideas on how to configure the Router in this fashion?
Richard Burts
It may help if you think about it in terms that within that module you have a small switch and you need to configure the switch. You would select the switch port that you want to use to connect to the ISP and configure it as an access port in a vlan that you create. Then you configure interface vlan and put the IP address on the vlan interface. Then you configure routing to use the address of the vlan interface.
Rick
Rick
