2911 with PVDM3-16 and VIC2-4FXO - all the status lights are amber
Balaji Ezhumalai
Hello All,
I have 2911 with PVDM3-16 and VIC2-4FXO
All the status lights are amber. The pvdm and voice card has been deducted and I am able to see them
through #show diag, show diag | i FRU, and other commands.
#show diag | i FRU
Product (FRU) Number : CISCO2911/K9
Product (FRU) Number : PWR-2911-AC
Product (FRU) Number : PVDM3-16
Product (FRU) Number : VIC2-4FXO
I have also checked my modules with another 2911 Router and the modules are working.
What will be the problem? Do i need to enable or activate anything?
Please help and thanks in advance.
3 Accepted Solutions
do you have IP Voice installed on the router ? Post the output of 'sh ver'...
Hello, Georg Pauwen,
Thank you for attending to my question.
***Here is the result of "sh ver"***
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.4(3)M1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Sat 25-Oct-14 03:34 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M9, RELEASE SOFTWARE (fc1)
Seoul uptime is 37 minutes
System image file is "flash0:c2900-universalk9-mz.SPA.154-3.M1.bin"
Last reload type: Normal Reload
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2911/K9 (revision 1.0) with 483328K/40960K bytes of memory.
Processor board ID FTX1523AJLD
3 Gigabit Ethernet interfaces
1 terminal line
4 Voice FXO interfaces
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device# PID SN
*1 CISCO2911/K9 FTX1523AJLD
Technology Package License Information for Module:'c2900'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase       ipbasek9 Permanent ipbasek9
security     None       None         None
uc             None       None         None
data         None        None         None
NtwkEss   None        None         None
CollabPro None        None         None
Configuration register is 0x2102.
**Which one is IP Voice here?
Hello Georg,
You are right, the uck9 was not activated before. I have activated it now and it is working.
I have used the following link to activate the uck9:
https://community.cisco.com/t5/collaboration-voice-and-video/understanding-cme-srst-license-activation/ta-p/3123270
export@cisco.com.
1 terminal line
License Info:
License UDI:
Device# PID SN
uc             None       None         None
data         None        None         None
Hello Georg,
