2950 programming for dummies
mike81
Community Member
good morning. I picked up a Catalyst 2950 for use in my house. It works fine but since I upgraded from 75/75 mps to 980/980 mps, the switch is only allowing speeds of 100 or less. I have no idea how to make changes to the configuration or if I can even do so. Any suggestions or recommendations would be appreciated.
Thanks!
keglass
Level 11
Level 11
We are researching your question and will respond shortly with an answer. Thank you for your patience.
Kelli Glass
Moderator for Cisco Customer Communities
shah
The Catalyst 2950 has been end of support since October 2013 (announced Oct 2007).  Great to hear it is still working.
EOS and EOL Announcement of Five Additional Cisco Catalyst 2950 Series Switches - Cisco
I think the issue is many of the WS-C2950 switches are 10/100Mbps switch.  Some of them have 1G uplinks as pasted in the table below.  However, the front panel are limited to 100Mbps.
Cisco Catalyst 2950 Series Switches with Standard Image SW  [Cisco Catalyst 2950 Series Switches] - Cisco Systems
ORDERING INFORMATION
Model Numbers
Configuration
WS-C2950-12
• 12 10/100 Mbps ports
• 1-RU standalone, fixed-configuration, managed 10/100 Mbps switch
• Standard Image (SI) Software
WS-C2950-24
• 24 10/100 Mbps ports
WS-C2950SX-24
• 24 10/100 Mbps ports with two fixed 1000BASE-SX uplinks
WS-C2950T-48-SI
• 48 10/100 Mbps ports with two fixed 10/100/1000BASE-T uplinks
WS-C2950SX-48-SI
• 48 10/100 Mbps ports with two fixed 1000BASE-SX uplinks
Here is the interface configuration guide:
Catalyst 2950 Desktop Switch Software Configuration Guide, 12.1(11)YJ4 - Configuring Switch Interfaces [Cisco Catalyst 2…
