2950 SNMPv3 Problem
ashley.watkins
I am busy rolling out SNMPv3 across our network infrastructure and has hit a snag with regards to the 2950 switch.
On all our other switches and routers I have 2 named access-lists,1 for our management range and 1 for our external monitoring service ip range to access, but when i attempt to bind the snmp v3 group to the named access list, I only get the option to choose a numbered access list.
Anyone had the same issue or have a suggestion?
The IOS on the switch is C2950-I6K2L2Q4-M
Giuseppe Larosa
Hello Ashley,
if a numbered ACL is supported on C2950 to define snmpv3 parameters I would use it.
Network documentation can be updated telling that on specific platforms a numbered ACL is used instead of a named ACL
try to see if you can use the remark keyword that allows to insert a comment line in the ACL, if so put a remark line with the name of the named ACL as first line in the numbered ACL.
access-list 101 remark like named ACL XXX
access-list 101 permit ...
Hope to help
Giuseppe
Giuseppe Larosa
Hello Ashley,
Hope to help
Giuseppe
Hi Giuseppe,
I did have that thought but wanted to see if there was any other option.
I will definitely be going with the numbered ACL and using the remark. Thank you for the feedback.
Ashley
