07-14-2008 05:33 AM - edited 03-06-2019 12:10 AM
Okay, so I'm wondering if this is possible...
I have one port that I want to plug machines in. They can either be on vlan 1 or vlan 189. Is there any way to set up the "switchport access vlan #" command to make it so that both those vlans have access to it?
07-14-2008 05:34 AM
Not as an access port.
Hope that helps.
07-14-2008 05:38 AM
There are specific cases when you use 2 different vlans, 1 for voice & other for data. This is what you do when your port participates in both voice & data.You specifically mention which vlan is for voice & which is data. Done as follows:
int fa0/0
switchport mode access
switchport access vlan 100
switch voice vlan 200
Other than such case, you cant have a single port as part of 2 vlans simultaneously.
