2950 switch - mls qos - NOT removing COS/DSCP values?
brettp
I am just now diving into COS/QOS and right away, I'm not getting far :( I am messing around on a 2950 switch. Based on what I read, when I enable "mls qos," any marked traffic entering the switch would have those values changed to 0. Is that correct? I have an Avaya VOIP phone attached that marks the DSCP value 46. When I use wireshark and capture that traffic (again, there is no other config on the switch except mls qos,) the DSCP value is still 46!? I thought it would be 0? Any ideas?
mls qos
interface fastethernet0/1
switchport access vlan 110
switchport mode access
switchport voice vlan 112
show mls qos
QoS is enabled
QoS ip packet dscp rewrite is enabled
I'm not afraid to show I'm an idiot... I'm back to post what the issue was. I was running wireshark and sniffing the ingress interface (duh!) thus I was seeing the marked traffic. I should have been sniffing the egress interface after the switch remarked the traffic.
Joseph W. Doherty
The general rule on most old(er) Cisco switches, if QoS is enabled, if the port doesn't "trust", the swtich resets CoS and/or ToS to zero.
However, that's a general rule. For how your 2950 should behave, you would need to read the documentation that applies to that particular model and its running IOS version vs. how it's configured.
