2950 sx 1 gigabit port is not giving led
upendra07
Dear
I have 2950 sx 24.It has 2 fiber gigabit port.I saw the laser led coming from the one port but the same other port it is not coming.It's switch related problem.
Please suggest me.
8 Replies 8
Giuseppe Larosa
Hello Upendra,
try to do the following:
swap gbics between the one that works and the one that doesn't work.
take note of results
try to swap fibers
final note: I would suggest to avoid to open multiple threads for the same issue delete the second one to avoid confusion.
Hope to help
Giuseppe
Dear
I tried but i obeserved one thing
when i see the working port i seen laser coming from the port but when i seen the bad port the laser is not coming from the port.
Hello Upendra,
I hope you are not using your eyes to check when the laser is transmitting this is not recommended !
Be also aware that we cannot see near infrared (second window is 1.3 micrometers lamdba and third window is in the range 1.5 micrometers).
Verify the part numbers of the GBIC there is a chance that you have mixed GBICs of different types.
see
http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_6981.html
as a reference.
There is also a chance that is not working well.
to check each gbic you can loop the fiber tx to rx.
Hope to help
Giuseppe
Dear
Any physical problem in port or any ios related problem.
There is also dust related problem.
Dust is in the Port
Leo Laohoo
Please try the command "sh post".
thanks
it's showing "Passed"
where we can use the command
Leo Laohoo
Have you tried replacing the fiber cable?
yes,
i think problem in port
can you tell me any command so i can check port status
