DAI and static addresses
John Blakley
All,
Say I have a core switch at 192.168.100.5, and I have a user add another switch on the network at their desk that's also addressed at 192.168.100.5. Is the best way to handle the situation by using dynamic arp inspection to shut down the port, or is dhcp snooping the best way?
We want to avoid having someone bring our core down. :)
John
HTH, John *** Please rate all useful posts ***
Edison Ortiz
You implement DAI along with ip arp inspection filter http://www.cisco.com/en/US/docs/ios/ipaddr/command/reference/iad_arp.html#wp1012267 for static IP assignment
and DAI with DHCP snooping for dynamic IP assignment.
More reading material
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/dynarp.html#wpmkr1047165
__
Edison.
Edison Ortiz
__
Edison.
dclark
Hi John
Both dynamic arp inspection and ip source guard utilize dhcp snooping, In short,use dynamic arp inspection to prevent users from changing their mac-addreses and use ip source guard to prevent illegal IP addresses from being used.
Basically arp inspection protects at layer 2 and ip source guard at layer 3.
Check the following link;
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_25_se/configuration/guide/swdhcp82.html
