2951 Routing Issues
jbatchos1
I have a 2951 and I'm trying to consolidate from 2 ISP connections down to 1. Current setup is 1 ISP is strictly for guest access, the other is for internal office access.
From the console I can ping all interfaces, clients on each interface and I can ping to the outside world. If I put my computer on the guest interface (gig0/1) or the office interface (gig0/2), I can ping only to the local interface I am connected to.
Example. When connected to interface gig0/1 I can ping 10.1.8.1 (ip of int gig0/1) and that's it.
The router config is vanilla, no access-lists, etc. I pulled it out ,configured the hostname, interfaces, and set an IP route.
Show IP route and Show Run to follow.
Gateway of last resort is 192.168.10.1 to network 0.0.0.0
S*    0.0.0.0/0 [1/0] via 192.168.10.1
      10.0.0.0/8 is variably subnetted, 4 subnets, 3 masks
C        10.1.0.0/24 is directly connected, GigabitEthernet0/2
L        10.1.0.7/32 is directly connected, GigabitEthernet0/2
C        10.1.8.0/21 is directly connected, GigabitEthernet0/1
L        10.1.8.1/32 is directly connected, GigabitEthernet0/1
      192.168.10.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.10.0/24 is directly connected, GigabitEthernet0/0
L        192.168.10.2/32 is directly connected, GigabitEthernet0/0
Building configuration...
Current configuration : 4487 bytes
! Last configuration change at 09:22:28 Eastern Thu Nov 7 2013 by admin
! NVRAM config last updated at 09:24:02 Eastern Thu Nov 7 2013 by admin
version 15.1
hostname XXXX
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
clock timezone Eastern -5 0
clock summer-time Eastern recurring
crypto pki trustpoint TP-self-signed-3345044724
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3345044724
revocation-check none
rsakeypair TP-self-signed-3345044724
crypto pki certificate chain TP-self-signed-3345044724
certificate self-signed 01
  <REMOVED>
        quit
no ipv6 cef
ip source-route
ip cef
ip domain name <REMOVED>
ip name-server 8.8.8.8
ip name-server 8.8.4.4
voice-card 0
license udi pid CISCO2951/K9 sn <REMOVED>
hw-module pvdm 0/0
username <REMOVED>
username <REMOVED>
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description GATEWAY
ip address 192.168.10.2 255.255.255.0
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
description GUEST Network
ip address 10.1.8.1 255.255.248.0
duplex auto
speed auto
interface GigabitEthernet0/2
description OFFICE Network
ip address 10.1.0.7 255.255.255.0
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 192.168.10.1
access-list 199 permit ip any any
nls resp-timeout 1
cpd cr-id 1
control-plane
mgcp profile default
gatekeeper
shutdown
line con 0
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
privilege level 15
login local
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
login local
scheduler allocate 20000 1000
ntp server 64.113.32.5 prefer
ntp server 216.171.148.102
end
22 Replies 22
Jason
Sorry that did not fix the issue. Perhaps when you are ready to work on this again it might help to give us some understanding of how things were/are that is working and what you are changing to that is not working.
Rick
Rick
Jason
It was late when the thought occurred to me that the  problem might be address translation and I posted my suggestion about  doing translation. In the clarity of morning when I look at my  suggestion I see a flaw in what I suggested. In addition to those  commands you should also do
interface gig0/0
ip nat outside
interface gig0/1
ip nat inside
interface gig0/2
ip nat inside
When you get a chance to get back to it give this a try and let us know if it helps.
Rick
Rick
Rick,
Thank you I will give that a try as soon as I can. In the mean time, here's a quick drawing of how we are now and what I'm trying to do.
Jason
Thanks for the drawing. I have a couple of questions  based on that but probably should wait until you are ready to work on  this again to get into them (especially when we know whether the revised  address translation is helpful).
Rick
Rick
Few things that erupted in my mind...
- Lets assume the translation is happening correctly  then are you able to ping the outside world from your router if  interface gig0/1 or 0/2 is chosen as source?
Whats the result of this ---- # ping 8.8.8.8 source gig 0/1
Also, would suggest you to remove these two lines from the config if you are not using these features -
# ip source-route
# ip forward-protocol nd
Negate the above commands if these features aren't used and let us know if there is any difference.
Talha.
ping 8.8.8.8 source gig0/2 --- Does not work.
negated the commands:
# ip source-route
above ping still does not work.
If that is not working then try the extended ping.
# ping      ---- hit enter
Target IP Address : 8.8.8.8
Extended Command : Y
Source Address Or Interface : gigabitethernet0/2 ---- or type in the gig 0/2 interface ip address
After negating the said commands are you able to ping all the router interfaces from your desktop?
Talha
Did not work.
