2960 and QoS Problem
richmnn
I have a 2960 that I'm having some QoS issues with.  An example of my config is listed below.
Extended IP access list IP_Audio
    10 permit udp any any range 50000 50019
    20 permit tcp any any range 50000 50019
Extended IP access list IP_Video
    10 permit udp any any range 57501 57519
    20 permit tcp any any range 57501 57519
Class Map match-any class-default (id 0)
   Match any
Class Map match-all Client-Video (id 1)
   Match access-group name IP_Video
Class Map match-all Client-Audio (id 2)
   Match access-group name IP_Audio
  Policy Map Client_Policy
    Class Client-Audio
      set dscp ef
    Class Client-Video
      set dscp af41
    Class class-default
      set ip dscp default
I have the service policy applied to ports fa0/1 along with the following configuration and the gig uplink port trusting dscp and it's configuration:
interface FastEthernet0/1
switchport access vlan 40
switchport mode access
switchport voice vlan 91
switchport port-security maximum 2
switchport port-security aging time 3
switchport port-security aging type inactivity
priority-queue out
no cdp enable
spanning-tree portfast
spanning-tree bpduguard enable
service-policy input Client_Policy
ip dhcp snooping limit rate 50
end
interface GigabitEthernet0/2
switchport trunk native vlan 999
switchport trunk allowed vlan 40,91,450
switchport mode trunk
switchport nonegotiate
ip arp inspection trust
priority-queue out
mls qos trust dscp
ip dhcp snooping trust
end
I have used WireShark to monitor fa0/1 and I see DSCP marking off the phone coming into the switch port  I then used WireShark to monitor the gig uplink port gig0/2.  At that point the UDP voice packets (that are in the specified port range of the access list) from the source IP address of the phone/softphone appears to have dropped the DSCP marking.  Packets coming in from the 4507 that the 2960 is connected to are still marked correctly though.  I'm at a loss as to what I'm missing to get this DSCP marking to work correctly.  I'd prefer not to set all the ports on the switch to trust dscp on the edge ports but so far that is the only thing that has been successful in testing.  Any help is appreciated.
9 Replies 9
Hello
By default voice media traffic is marked with a cos 5 and dscp EF = 46
On cisco switches the cos to dscp marking defaults to for cos 5 = 40
sh mls qos maps cos-dscp
   Cos-dscp map:
        cos:   0  1  2  3  4 5  6  7
       dscp:   0  8 16 24 32 40 48 56
Can you try changing this default?
conf t
mls qos map cos-dscp  0  8 16 24 32 46 48 56
SW1#sh mls qos maps cos-dscp
   Cos-dscp map:
       dscp:   0  8 16 24 32 46 48 56
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
I went ahead and changed the COS-DSCP mapping on the switch so that COS 5 maps to 46 as you suggested.  After doing some more testing, this unfortunately did nothing to solve the problem I'm seeing on the switch.  I should have stated before, that the phones & softphones are set up to mark voice traffic with a value of 46 and not a COS value of 5.  Thanks for the quick response and let me know if you have any other suggestions.
Hello
Okay so you are saying the dscp values comes into the fa0/1 and before it goes out of gig0/1 they are dropped?
int fa0/1
mls qos trust dscp
sh mls qos
sh mls qos inter fa0/1
sh mls qos inter gig0/1
res
Paul
Thanks.
Kind Regards
Paul
Yeah, that's what it is looking like to me.  If I monitor fa0/1 I will see the DSCP value set for both incoming and outgoing packets.  If I then monitor gig0/2 I will see the DSCP value set to EF for packets destined for the phone/softphone.  However the packets headed out of the switch to the server have the DSCP marking of 0.
Output of sh mls qos, sh mls qos int fa0/1, and sh mls qos gig0/1
#sh mls qos
QoS is enabled
QoS ip packet dscp rewrite is enabled
#sh mls qos int fa0/1
FastEthernet0/1
Attached policy-map for Ingress: Lync_Client_Policy
trust state: not trusted
trust mode: not trusted
trust enabled flag: ena
COS override: dis
default COS: 0
DSCP Mutation Map: Default DSCP Mutation Map
Trust device: none
qos mode: port-based
sh mls qos int gig0/2
GigabitEthernet0/2
trust state: trust dscp
trust mode: trust dscp
COS override: dis
default COS: 0
Trust device: none
I would prefer not to just trust the DSCP values coming off the edge devices if possible.  I would prefer that the service policy sets the DSCP value for the UDP packets in those port ranges if at all possible.
Hello
When the traffic heads outs of the switch its subject to whatever device it traverses and if that is another cisco switch then by default the switch will rewrite the dscp value to zero if qos is enabled also.
QoS is enabled
Sh policy-map int fa0/1 & gig0/1
What is connected to gig0/1?
Can you provide a simple toplogy?
res
Paul
Thanks.
Kind Regards
Paul
It's your basic hub and spoke design. Clients and phones connect to the 24 Ethernet ports. Int gig0/2 is up linked to 4507 that is the main core switch for the building and the IP telephony server is plugged into the 4507. The service policy is applied to the 24 ports used for client access that was shown in the previous example configuration. The gig port 0/2 trusts dscp values with the mls qos trust dscp command.
When I monitor the port fa0/1 that the client phone is connected to, I see the correct dscp value. The phone is set to use the dscp value of 46. When I monitor the uplink port gig0/2 the dscp value is dropped on packets leaving the 2960. This is before it even hits the 4507 that it is connected to. During testing I tried trusting dscp values on fa0/1 using mls qos trust dscp. When that was set on port fa0/1, the dscp value would then be passed onto the gig0/2 uplink port for traffic destined for the 4507. It appears that the service policy is not setting the dscp value I have assigned like it should be. The phone is using the correct udp port ranges I have specified in the access list. I could just set the port fa0/1 to trust any dscp value coming off the clients, but it is not really and optimal solution in our environment.
Hello Again
Okay given that it works when you trust the interface try and trust the policy-map instead.
    Class Client-Audio
     trust dscp
      set dscp ef
    Class Client-Video
      trust dscp
      set dscp af41
     Class class-default
      trust dscp
      set ip dscp default
res
Paul
Thanks.
Kind Regards
Paul
I see the same result when trusting dscp in the policy-map as I do when assigning dscp in the policy map.  When monitoring the fa0/1 port that the phone is connected to I see the DSCP EF value.  When I monitor gig0/2 uplink port the dscp value is set again to 0.
I figured out my problem.  The problem was with my access list.  The access list in my configuration were the following:
However, I'm looking for the source port ranges for TCP and UDP packets.  I changed the access list to the following and it cleared up my problem.
    10 permit udp any range 50000 50019 any
    20 permit tcp any range 50000 50019 any
    10 permit udp any range 57501 57519 any
    20 permit tcp any range 57501 57519 any
Thanks for your help with this problem.
