2960 Direct communication between them is not possible !!!!!
Two 2960s are directly connected by UTP.
However, 2960 ping can not be done.
Attach the configuration below.
1_2960>
interface GigabitEthernet0/43
  switchport access vlan 318
  switchport mode access
interface Vlan318
  ip address 172.26.18.5 255.255.255.0
2_2960>
interface GigabitEthernet1/0/24
interface Vlan318
  ip address 172.26.18.8 255.255.255.0
CDP neighbor information is normal.
I attach the whole Config below.
Hi.
Thanks for the answer.
There was an IP management solution here and it did not ping.
Thank you ^ ^
Mark Malone
you should be able to arp in same vlan , what does the show mac and show arp for both interfaces show you , if there incomplete ping wont happen as layer 2 not working at MAC level
also could be local firewall on the devices your pinning from blocking ping , some string AVs will block pings , turn it off as a test
sh ip arp tenGigabitEthernet x/x/x
sh mac address-table interface tenGigabitEthernetx/x/x
also make sure STP is FWD for vlan 318 on  the trunk link
sh spanning-tree vlan 318
Hi.
Thank you ^ ^
