2960 factory reset and restore of web interface
Hello everyone,
I'm admittedly new here and recently came into possession of an old Catalyst 2960 model WS-C2960-48PST-L. This switch was removed from service due to a network refresh and the guys were nice enough to donate it to me for my home system. My current system has a Netgear 8 port switch, Cisco WS-C2960G-24TC-L and an 8 port Milan PoE switch. I'm looking to replace the 3 current switches with the slightly newer donated one. My issue is that my Cisco experience is limited to the simple web interface. I'm not a CLI guy by any stretch of the imagination.
The donated switch was "wiped" by the donating IT department. I think they deleted CONFIG.TEXT and the VLAN information. The web interface does not load (404 not found) and I'm looking to restore it to this switch. I spent almost a day googling different solutions, downloading BIN and TAR files, poking away on PUTTY and FTPing files. It was toward the end of that first day I realized I downloaded the files for the wrong switch. Once I got the proper BIN file in there the switch booted but no web interface. Tried the TAR file but no luck there either. Discovered during the second or third day that there was no HTML folder in FLASH: and modified the TAR file to extract hopefully in the proper place. Web interface loaded to first screen but would not go further. After contemplating percussion therapy with a big hammer, I finally walked away from it for a while.
Look guys, I don't care what was or is on the switch. I just want to restore it to a state where I have the web interface and can enable/disable the channel, PoE, can give the channel a name and do some basic monitoring of traffic numbers. This has to be almost a dummies version because that's what I am.
Thanks for any help given.
Mike
This is because of the Local certificate issue, is this from Chrome ? try firefox or IE let us know.
BB
balaji.bandi
GUI comes with a TAR file, if you booted with .bin file you will not get any GUI - For us  to help you better, if the device is booted  and you have a console connected
post below output :
show version
dir
For example below "d" means directory, then you can get GUI here.
drwx 192 Mar 01 1993 22:30:48 c2960-lanbase-mz.122-25.FX
BB
Thank you for the reply. I haven't completely given up and did some more googling. I also have the non-PoE switch I've been able to telnet into and look at the structures and files.
Space on the switch keeps killing me but I was able to get the proper file versions. Using that and the old switch as an example, I did the following:
Iinstalled and booted the BIN file then deleted the BIN and used the command
archive tar /xtract tftp://192.168.1.205/c2960-lanbasek9-tar.122-55.SE12.tar flash:
I then changed the boot path and restarted the switch. It boots properly but I still don't have a proper web gui. I'm given the choice to use a secure session. Choose no and I can't do anything in the GUI (of course). Choose yes and I get:
This site can’t provide a secure connection
192.168.1.206 uses an unsupported protocol.
ERR_SSL_VERSION_OR_CIPHER_MISMATCH
and
Unsupported protocol
The client and server don't support a common SSL protocol version or cipher suite.
Here is the show version info you asked about:
Switch#show version
Cisco IOS Software, C2960 Software (C2960-LANBASEK9-M), Version 12.2(55)SE12, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2017 by Cisco Systems, Inc.
Compiled Thu 28-Sep-17 02:53 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x01900000
ROM: Bootstrap program is C2960 boot loader
BOOTLDR: C2960 Boot Loader (C2960-HBOOT-M) Version 12.2(46r)SE2, RELEASE SOFTWARE (fc1)
Switch uptime is 14 minutes
System image file is "flash:/c2960-lanbasek9-mz.122-55.SE12/c2960-lanbasek9-mz.122-55.SE12.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C2960-48PST-L (PowerPC405) processor (revision D0) with 65536K bytes of memory.
Processor board ID FOC1511Z41N
Last reset from power-on
1 Virtual Ethernet interface
48 FastEthernet interfaces
4 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
64K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : E8:40:40:B6:79:00
Motherboard assembly number : 73-11882-09
Power supply part number : 341-0266-03
Motherboard serial number : FOC15105WL8
Power supply serial number : DCA1507HJD3
Model revision number : D0
Motherboard revision number : A0
Model number : WS-C2960-48PST-L
System serial number : FOC1511Z41N
Top Assembly Part Number : 800-30874-04
Top Assembly Revision Number : E0
Version ID : V03
CLEI Code Number : COMC400ARA
Hardware Board Revision Number : 0x01
Switch Ports Model SW Version SW Image
* 1 52 WS-C2960-48PST-L 12.2(55)SE12 C2960-LANBASEK9-M
Configuration register is 0xF
And also the flash: contents:
Switch#dir flash:
Directory of flash:/
2 -rwx 399 Mar 1 1993 00:07:03 +00:00 express_setup.debug
3 drwx 512 Mar 1 1993 00:24:53 +00:00 c2960-lanbasek9-mz.122-55.SE12
559 -rwx 3096 Mar 1 1993 00:06:30 +00:00 multiple-fs
560 -rwx 2379 Mar 1 1993 00:06:30 +00:00 config.text
561 -rwx 108 Mar 1 1993 00:30:32 +00:00 info
562 -rwx 1915 Mar 1 1993 00:06:30 +00:00 private-config.text
27998208 bytes total (14097408 bytes free)
Switch#dir flash:/c2960-lanbasek9-mz.122-55.SE12
Directory of flash:/c2960-lanbasek9-mz.122-55.SE12/
4 -rwx 539 Mar 1 1993 00:24:53 +00:00 info
5 -rwx 9827106 Mar 1 1993 00:24:53 +00:00 c2960-lanbasek9-mz.122-55.SE12.bin
6 drwx 5632 Mar 1 1993 00:28:46 +00:00 html
Switch#
I feel like even with all my bumbling I'm getting close. If I can get the secure web gui working, should be in good shape!
Thanks!
BB
Sorry, I was away for a couple days.
This was occurring in Chrome. I tried internet explorer as you suggested and after enabling a couple security options it is now working.
What an adventure this was! Thanks for all the help!
Mike
