2960 Firmware update issue
chris2222
Hi, I'm looking for some advice relating to a firmware update I just attempted.
Switch: WS-C2960-48TC-S
Existing Firmware:15.2(2)E6
New Firmware:15.2(2)E7
Downloaded file:c2960-lanlitek9-tar.152-2.E7.tar
I'm not a Cisco expert and I've always used the web GUI.
I processed a software update from the GUI which involved browsing for the file, uploading it and letting the switch do it's thing.
Afterwards, I connected to the switch and was presented with an HTML Page I was unfamiliar with. One of the options on the page is "Web Console. Manage the switch through the web interface". When I click this, I get a 404 error.
So I'd suggest the update didn't work, or the switch didn't restart. I'm reluctant to restart it at this stage, as it is in use - just in case it doesn't boot up again.
One of the options on the html "Switch Home Page" is "Monitor the router" - which takes me to http://ip.ip.ip.iplevel/15/exec/- and gives me the ability to type in commands. Here's what I've found...
Command base-URL was: /level/15/exec/- Complete URL was:/level/15/exec/-/sho/version/CR Command was: sho version
Cisco IOS Software, C2960 Software (C2960-LANLITEK9-M), Version 15.2(2)E6, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Sat 17-Dec-16 00:27 by prod_rel_team
ROM: Bootstrap program is C2960 boot loader
BOOTLDR: C2960 Boot Loader (C2960-HBOOT-M) Version 15.0(2r)EZ1, RELEASE SOFTWARE (fc2)
Switch uptime is 2 days, 14 hours, 19 minutes
System returned to ROM by address error at PC 0x160BD3C,                          address 0x0
System image file is "flash:/c2960-lanlitek9-mz.152-2.E6/c2960-lanlitek9-mz.152-2.E6.bin"
Last reload reason: address error at PC 0x160BD3C,                          address 0x0
Command base-URL was: /level/15/exec/- Complete URL was:/level/15/exec/-/sho/flash/CR Command was: sho flash
Directory of flash:/
    2  -rwx        3096   Mar 2 1993 16:37:55 +00:00  multiple-fs
    3  -rwx         156   Mar 1 1993 00:01:21 +00:00  express_setup.debug
  609  -rwx        3561   Mar 2 1993 16:37:55 +00:00  config.text
  610  drwx         512   Mar 3 1993 06:35:12 +00:00  c2960-lanlitek9-mz.152-2.E7
  586  drwx        1024   Apr 6 1993 20:29:27 +00:00  crashinfo_ext
  596  drwx         512   Mar 1 1993 00:29:51 +00:00  dc_profile_dir
  598  drwx        1024   Mar 1 1993 00:00:19 +00:00  crashinfo
  607  -rwx        1914   Mar 2 1993 16:37:55 +00:00  private-config.text
61028352 bytes total (40136704 bytes free)
 Any help you can offer to assist me in getting the firmware correctly updated and the web GUI back is very greatly appreciated. Thank you for your time.
13 Replies 13
Leo Laohoo
The wrong firmware has been loaded.
The switch is a plain 2960 but the IOS loaded is for a 2960 LAN Lite.
Thank you for your response Leo, but you are incorrect.
Lan Lite is the correct firmware for this switch...
https://www.cisco.com/c/en/us/products/switches/catalyst-2960-series-switches/models-comparison.html
WS-C2960-48TC-S LAN Lite Entry Layer 2
I updated another switch with the same firmware and it is fine. This firmware was the one recommended in the Cisco support area for this switch model.
He he he ... I am wrong there.
Ok, so can you post the complete output to the command "dir flash:crashinfo_ext"?
Great, thanks for helping me :-)
Directory of flash:/crashinfo_ext/
587 -rwx 388012 Apr 6 1993 20:29:27 +00:00 crashinfo_ext_1
588 -rwx 383109 Apr 2 1993 11:31:17 +00:00 crashinfo_ext_2
589 -rwx 388325 May 11 1993 10:51:41 +00:00 crashinfo_ext_3
590 -rwx 384615 Mar 1 1993 01:05:23 +00:00 crashinfo_ext_4
591 -rwx 389311 Mar 1 1993 00:11:14 +00:00 crashinfo_ext_5
592 -rwx 398168 Mar 31 1993 13:09:47 +00:00 crashinfo_ext_6
593 -rwx 382976 Mar 9 1993 06:08:30 +00:00 crashinfo_ext_7
594 -rwx 387592 Mar 3 1993 02:58:53 +00:00 crashinfo_ext_8
595 -rwx 378888 Mar 2 1993 05:39:53 +00:00 crashinfo_ext_9
Any help you can offer is greatly appreciated.
Is the switch time & date set correctly?
Post the complete output to the command "more flash:crashinfo_ext/crashinfo_ext_9".
There is no option on the switch to set the time and date. The switch is a 2016 model - so the time and date are incorrect. I've attached the output in a txt file as it is too large to paste here.
Is there any reason why you want to use this version? Any feature(s)?
If not, downgrade to 15.0(2)SE train and see if there's any improvements.
With the switch in this current state, I have no idea how to do anything with it.
The switch came with 15.2(2)E6 installed. The recommended version by cisco is the one I jut tried to install.
I only know how to use the web interface - but this is now broken.
I need to know how to update the firmware correctly and get back the web interface. Before, when using the browser I could upload the firmware file - but now it is broken I don't know what to do. This is the problem I am asking about.
You ask me to switch to a different firmware but I don't have any knowledge to do that. That's why I posted this topic.
Can you help?
Go HERE.
I'm 27 minutes into that video and still so far have not seen any instructions. This is very painful. Nothing in that video looks like, or equates to the situation I am in right now. I'm sorry but it is entirely unhelpful.
As mentioned, I'm at an unfamiliar plain HTML page when logging into the switch in my browser, the uploaded tar file with the ios image appears to be there. I seem to be able to enter commands on that interface but I have no option to upload a new tar file, or any knowledge about how to install the one that is there. I don't have telnet access to the switch.
Is there perhaps anyone else who has a better understanding of my situation that can assist me?
Unless others can chime in, I'd recommend raising a TAC Case.
The Release Notes of every IOS version also contains instruction(s) on how to upgrade the IOS of a switch.
