2960 LACP and VLan Issues
rkovelman
All,
I appreciate any assistance on this.  I just setup LACP on ports 3-4 and it is not working.  Once I place the ports on vlan 1 the ports go inactive.  If I place the ports on vlan 10 for instance they go live and are green.  If they are on vlan 10 I can not see the server or anything.  Any ideas?  What information do you need other than what is below.
Here is info with them on VLAN 1
interface GigabitEthernet0/3
description Zeus LACP
channel-group 5 mode active
interface GigabitEthernet0/4
vlan internal allocation policy ascending
spanning-tree mode rapid-pvst
spanning-tree loopguard default
Cisco-2960#sh lacp counters
             LACPDUs         Marker      Marker Response    LACPDUs
Port       Sent   Recv     Sent   Recv     Sent   Recv      Pkts Err
Channel group: 5
Gi0/3       57     3448     0      0        0      0         0
Gi0/4       57     3448     0      0        0      0         0
Cisco-2960#sh lacp internal
Channel group 5
                            LACP port     Admin     Oper    Port        Port
Port      Flags   State     Priority      Key       Key     Number      State
Gi0/3     SA      susp      32768         0x5       0x5     0x104       0x5
Gi0/4     SA      susp      32768         0x5       0x5     0x105       0x5
Group: 5
Group state = L2
Ports: 2   Maxports = 16
Port-channels: 1 Max Port-channels = 16
Protocol:   LACP
Minimum Links: 0
Cisco-2960#sh etherchannel protocol
Channel-group listing:
Group: 5
Protocol:  LACP
Thanks Again!
2 Accepted Solutions
Thanks for your reply. Sorry, my mistake I wanted to ask for 'sh run int po5' instead of 'sh int'. By the way, based on your logs, it looks like the problem is that the channel members and port-channel interface configuration are not consistent. In order for the port-channel to work properly, the members need to have the same configuration, as well as the port-channel interface.
I would suggest to try the following, as you're using vlan 1 only:
conf t
int ra gi0/3 - 4
switchport mode access
switchport access vlan 1
int po5
Let me know if this helps. If not, please provide me with the following:
sh run int gi0/3
sh run int gi0/4
sh run int po5
Yes, you need to configure the same settings (like same vlan) for both member ports, gi0/3 and gi0/4 if you are using those. That's why I was using 'int ra' in my example, which means 'interface range' so that you can configure multiple ports at the same time.
8 Replies 8
andtoth
Level 4
Level 4
It would be good to know the following:
- What device is connected on the other side?
- How is the other side configured?
- Is the other side configured as a trunk port or access port?
- Configuration of interface Port-channel5 (sh int po5).
- Output of 'sh etherchannel 5 summary' when it's working and when it's not working.
- Do you see any error messages in the logs (sh log) ? If yes, paste some here.
Andras
Thanks for the reply.  Below is what you asked for:
1) Apple Xserve (2010 purchase)
2) The 2 ports are bound together
3) I assume an assess port
4) Cisco-2960#sh int po5
Port-channel5 is down, line protocol is down (notconnect)
  Hardware is EtherChannel, address is 0017.0e8f.9a04 (bia 0017.0e8f.9a04)
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive set (10 sec)
  Auto-duplex, Auto-speed, link type is auto, media type is unknown
  input flow-control is off, output flow-control is unsupported
  Last input never, output 00:36:30, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     2005 packets input, 177522 bytes, 0 no buffer
     Received 2005 broadcasts (268 multicasts)
     0 watchdog, 268 multicast, 0 pause input
     2218 packets output, 200076 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
Number of channel-groups in use: 2
Number of aggregators:           2
Group  Port-channel  Protocol    Ports
5      Po5(SD)         LACP      Gi0/3(s)    Gi0/4(s)
Logs
02:13:41: %EC-5-CANNOT_BUNDLE2: Gi0/3 is not compatible with Gi0/4 and will be suspended (access vlan of Gi0/3 is 1, Gi0/4 is 10)
02:13:41: %EC-5-CANNOT_BUNDLE2: Gi0/3 is not compatible with Po5 and will be suspended (access vlan of Gi0/3 is 1, Po5 is 10)
02:13:41: %EC-5-CANNOT_BUNDLE2: Gi0/4 is not compatible with Po5 and will be suspended (access vlan of Gi0/4 is 1, Po5 is 10)
02:13:42: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/3, changed state to down
02:13:42: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/4, changed state to down
02:13:42: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel5, changed state to down
02:13:43: %LINK-3-UPDOWN: Interface Port-channel5, changed state to down
Let me clarify working and not working.  The activity lights are green when they are set to any vlan other then 1.  Once they are on vlan 1 the output above shows.  The whole network is on vlan 1.  Again let me know what you need and I will provide it.
Message was edited by: rkovelman
conf t
int ra gi0/3 - 4
int po5
sh run int gi0/3
sh run int gi0/4
sh run int po5
You are the man!!  Thanks!
I will need to do the same for port 1 and port 2 is that ok?
esomarriba
Level 5
Level 5
Cisco 2960 -> PORT-CHANNEL -> Apple Xserver? is this right?
What do you mean by this:
The layout is as follows:
Xserve -> 2 ports are link aggregated, or bonded in OS -> Cisco
